Fuel line routing opinions
Hi guys, I relocated my tank to the rear and finally got around to running my fuel lines. I ran 3/8 aluminum line and 5/16 for my return line. I bundled them together using 5/8 insulated clamps. Looking for your guys opinions on how they look and if you see any issue with how they are ran. Thanks! Your pics are welcome!
Re: Fuel line routing opinions
2nd pic
3rd, dunno why there posting upside down
The routing looks fine. The only potential issue is if they chaff touching each other like that. On OE gm vehicles dual lines are usually clamped separated from each other. I'm not saying it is an issue, just something to consider.
It is considered best practice to clamp the lines singly. The idea of a padded clap is to prevent abrasion of the line which you are negating by clamping them loosely together. Any relative motion is abrading the lines at contact points.
You would do well to take a look at the factory servixe manuals for routing, fill and vent practices on Blazers and Suburbans. Having factory rear tanks they are very good models to pattern from. RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
As others have mentioned, your lines will chafe against each other at each clamp location. Separate each line from each other and you should have no problems. Each clamp should hold one line. 5/8" is too large for your lines. Add another clamp at each location 180 degrees off center of clamped line. For third line, stagger the clamp further down the line. If you need good clamps look at aircraft supply places like aircraft spruce or mcmaster-carr.
The lines immediately forward of the fuel tank: spread them apart if possible (third photo). There appears to be a point where clamp on one line is rubbing or may rub on the other line. If possible, please place a clamp on the line where it appears you have placed a pinch in between two lines (Brass fitting in photo one). Believe it or not, this weighs more than the surrounding line and may fail, cause leaks, vapor problems. You may not think it is not a big deal however, when you get into weight concerns vs. fluid dynamics and harmonics/frequencies, this may be a problem in the future. Also ensure each clamp is snug but not tight. Ensure the clamp does not pinch the line but retains the line in its location. You are looking to retain the line, not restrain the line. Hope that makes sense. I hope I do not come across as blasting you. You have done some great work and I just want to ensure you do not have problems in the future.
My other vehicle is unmanned.... |
Thanks guys they are clamped tightly together. Should I still be worried?
![]() Join Date: Oct 2004
I would separate the lines! On my Burb the fuel and brake lines are on there own clip!
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
Fixed
#10 | |
Perhaps steels lines are more forgiving. And yes, I've seen many aluminum A/C lines rubbed through. edit, if your saying the brakes are in one clamp and fuel/vapor in another you could be correct. I didn't remove the brake lines. I thought the brake lines were down the drivers side and fuel/vapor down the passenger (Suburban)
I went back as close to original fuel lines as I could. Mine had vent, brake, and fuel lines stacked on top of each other until each split off. 1 clamp held all three but on top of each other, not overlapping.
I also used the original brake and vent lines and only replaced the fuel line with Poly Armor which is a steel line. I haven't started the truck up yet so there is that. |
On my 69 Suburban the fuel and brake lines run on the passenger side separate from each other.
I think I'm going to just start over, would any of you guys have pics of the fuel routing? I have a vent line going to the filler, should I run 0ne more?
![]() Join Date: Mar 2014
Just another idea I used plastic line for all my fuel line. It was fast and easy looks great. I bought a kit that has lines, fitting everything you need but fuel filter. Kp1200 kit by sur&r
