07-06-2015, 01:23 PM | #1 |
A/c in 72 burb finally working
Well after lots of time and money, it is finally alive. Replaced: R4 compressor (I have a late model crate motor), dryer, expansion valve, and the POA valve delete upgrade from Classic Air. Result....44 degree vent air....nice and cool now both front and back units!!!! I weighed in the charge of 3lb 3oz of 134A.
Best advise I can give, if you are having issues is to flush your condenser and evaporator coils. I couldn't believe the amount of nasty oil came out of those things (especially the evaporator). Basically the system was oil logged and couldn't move any refrigerant. Plus I will assume that the nasty oil caused the factory POA valve and expansion valve to be clogged. After 40 years, you never know how much oil has been added or what has been truly done to your system. All is well now and the wife is happy....now we can take the Burb to the Street Nationals next month!!!! |
07-06-2015, 03:54 PM | #2 |
Re: A/c in 72 burb finally working
Congratulations on getting the AC going. Good advice on the flushing. Did you flush with refrigerant?
07-06-2015, 04:02 PM | #3 | |
I vacuumed the system for 8 hours and held the vacuum overnight to be sure it was good. |
07-06-2015, 04:14 PM | #4 |
This is great advice! How much was the flushing agent?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-06-2015, 06:36 PM | #5 |
Good news. Any pics of the engine compartment connections?
Using a R4 moves the lines closer to the core support making the use of an "off the shelf" OE line more difficult. Did you change the condenser? I thought my mastercool set would make new ends for the hard line but it doesn't do 1/2" line. My plan is to cut, swage and weld to make some new ones.
07-07-2015, 08:55 AM | #6 | |
