Old 07-10-2015, 05:16 PM   #1
albaniadiadem
New cam?
Im currently running lunati vodoo cam in a 355 with vortec heads, flattop pistons. Current cam specs are.
Basic Operating RPM Range: 1,000-5,500
Intake Duration at 050 inch Lift: 213
Exhaust Duration at 050 inch Lift: 219
Duration at 050 inch Lift: 213 int./219 exh.
Advertised Intake Duration: 256
Advertised Exhaust Duration: 262
Advertised Duration: 256 int./262 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.468 in.
Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.468 exh.
Lobe Separation (degrees): 112
Im wanting more power and my question is how much HP will i gain from switching to one of these cams. Note my heads already have new springs to support a bigger lift.
Basic Operating RPM Range: 1,400-5,700
Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 227
Duration at 050 inch Lift: 219 int./227 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 268
Advertised Duration: 262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.468 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.489 in.
Valve Lift with Factory Rocker Arm Ratio: 0.468 int./0.489 exh.
or this cam
Basic Operating RPM Range: 1,800-6,000
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 286
Advertised Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.490 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.490 in.
Valve Lift with Factory Rocker Arm Ratio: 0.490 int./0.490 exh.
Lobe Separation (degrees): 110
or this
Basic Operating RPM Range: 1,800-6,200
Intake Duration at 050 inch Lift: 227
Exhaust Duration at 050 inch Lift: 233
Duration at 050 inch Lift: 227 int./233 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.489 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.504 in.
Valve Lift with Factory Rocker Arm Ratio: 0.489 int./0.504 exh.
albaniadiadem is offline   Reply With Quote
Old 07-10-2015, 06:01 PM   #2
rich weyand
rich weyand's Avatar
Re: New cam?
You'll turn your truck into a slug. Look at those rpm ranges. As those go up, torque at low rpm goes down. Horsepower is all fine and dandy on the track, but on the street you drive torque.
All of those cams will feel weaker for a street truck than what you are running now.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 07-10-2015, 08:11 PM   #3
Jake Wade
Jake Wade's Avatar
Re: New cam?
Rich is spot on, the bigger cams will make more HP but, at a higher rpm. What you gain up top, you lose at the lower end, where you spend most of your time on the street.
What you really want is more cubes.
Jake Wade is offline   Reply With Quote
