Registered Loser
Window Track Mount Help Needed.
On my driver side door the weldnut that holds the window track bracket to the inside of the door broke loose and now the braclet is flopping around inside the door. Does anyone repop these parts? It is the bracket that is inside the door on the back edge by the striker. It is held in by screws going into the outside edge of the door. I will try to get pics later today.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
Re: Window Track Mount Help Needed.
Sounds like this piece....and its not reproduced. You'll have to source a used one. This is a driver side I just got rid of. I'd try the classifieds with a want to buy listing.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Chevy addict
Weld or braze the nut back in, could even use JB weld.
If not, I probably have a good used one I'd get rid of. |
Registered Loser
Thats the piece.
I guess I'll take it out tomorrow and see if I can get the nut tacked back in. Thaynks guys.
May be a good option to try a riv nut.....depending on how the old one came off.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
#7 | |
Registered Loser
Yeah...riv nut would only work if a new piece was welded in and a new hole drilled to accept it.
Registered Loser
Here's what I came up with...
![]() Seems to work great. The window goes up and down easier and for some reason my door even opens and closes easier now too.
Glad you got it resolved Creep!!!
![]() Join Date: May 2010
Nice job creep!
It only has original paint once |
Registered Loser
Thanks guys.
