07-17-2015, 10:55 AM | #1 |
OEM 60-66 choke cable needed - any condition, please read
In need a 60-63 Deluxe choke knob to help complete a project. I have found a donor cable, but still the knob to finish it off
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-23-2015 at 01:15 PM. |
07-17-2015, 11:18 AM | #2 |
One foot in front of the other
Re: OEM 60-66 choke cable needed - any condition, please read
Almost positive I have the cable only that would work for you. I am on vacation right now and will be back in TN the first of next week and will check.
07-17-2015, 11:32 AM | #3 |
Sounds good and thanks for responding. Do you happen to have an extra deluxe choke knob?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-17-2015, 10:05 PM | #4 |
I don't believe I do- but will check Mon/Tu
07-20-2015, 09:37 PM | #5 |
I have the cable only- no bezel or knob- that work for you?
07-21-2015, 09:56 AM | #6 |
The bezels are normally attached to the cable at the factory and just held on by a nut on the back. Can you supply a pic of what you have? I can work on finding a knob, but not sure that a bezel can be added once removed the way they built the cables.
07-21-2015, 10:36 PM | #7 |
Pics
07-23-2015, 09:24 PM | #8 |
That is correct choke cable DPOWERS
for 64-66. |
07-22-2015, 09:45 AM | #9 |
I appreciate it, but that doesn't appear to be a factory cable. The cables should be held on by a nut on the back side of the dash and that one is from the front. Also...the knobs were pressed on, not screwed on. Thanks for the time and pics though.
Pics of NOS parts for reference in the differences
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-22-2015 at 09:51 AM. |
07-22-2015, 07:10 PM | #10 |
ahhh don't remember where I got that one from.
good luck with the hunt |
07-22-2015, 08:51 PM | #11 |
cable shipped
07-23-2015, 10:21 AM | #12 |
Part found. Still need a deluxe choke knob.
07-23-2015, 10:17 PM | #13 |
Now know difference between 60-63 and 64-66 thanks
07-24-2015, 09:27 AM | #14 |
Thanks for the clarification LT1 Burb....I didn't know the differences myself. And thanks DPowers for your time and help also!!
