07-21-2015, 11:40 AM | #1 |
Improving the ride? Anyone use coil overs?
I have a Mustang 2 front end on my '59. It rides fair, kinda squeaks a bit. I guess if I could go back I would've put air bags on it to ride great but not sure I want to go back and do that now. I'm wondering if a good quality set of coil-overs would be worth the money? I'm looking for ride quality, not handling or a stiffer ride. Does anyone here have a set of RideTech or QA1 coil overs they can tell me more about?
'59 Big Window Fleetside |
07-22-2015, 09:13 AM | #2 |
Re: Improving the ride? Anyone use coil overs?
Jemo, I switch over to QA1's on my 50 pickup and I very happy with the outcome. You can check out what I did in my build thread starting on page 23 post #567. Any question let me know...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-22-2015, 12:58 PM | #3 |
I ended up with a lighter Mustang ll coil spring and a Bilstine shock for the Mll stock arms and my ride has 65K and it rides and handles great
07-22-2015, 01:12 PM | #4 |
I read Jimbo's post in his build thread and think I'm having the same issues. TCI tells me the coil springs in my truck are 375#. I also have a pinched upper ball joint boot. I called TCI and they said the pinch will go away as the coils start to settle but meanwhile I have a bad boot. I called QA1 and they suggested the same thing they did as Jimbo - a 700 lb spring. He was surprised the spring in the kit is 375#.
07-22-2015, 07:36 PM | #5 |
Jeff, just a side note, my name is Jim. Jimbo is a friend of mine I built the 67 for. As a group we need some pics, so we can all agree on what design you have. Also what type of spring you currently have. A stock coil spring for MII, coil-over spring, long or short will all make a difference...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 07-23-2015 at 02:38 PM. |
07-23-2015, 11:44 AM | #6 |
if your mustII was made for coil springs it would not be an easy conversion to coil overs
i have a fatman mustII that started squeaking after 5000 miles, at 12,000 miles the bushings were worn out fatman recommended no lube on the rubber bushing as they were graphite impregnated when i re-bushed my front end last year i used energy products grease and have no squeaks in 10,000 miles
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-26-2015, 07:46 PM | #7 |
I have 50AD with MII front end and QA1 coil overs made for MII coil spring setup. Ride is really nice, and with a decent sway bar the handling is also good. I found vehicle weight info on Ride Tech web site plus recommended spring rates. I used that to pick springs, don't remember what they were and can't find receipt.
