07-25-2015, 04:15 PM | #1 |
user # 2756
centering steering wheel
I pulled my steering wheel on my 83 to center it, it was off by 90 degrees. Under the steering wheel is a black plastic piece that is not on my 86. How do I get it off and do I need to do anything with the lock ring? The steering column is tilt if that matters. Any help is appreciated. Thanks,
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-25-2015, 08:33 PM | #2 |
user # 2756
Re: centering steering wheel
So I got the lock ring off and because of the way it is "keyed" I can not rotate it with the horn contact and cancelling cam to center the steering wheel.
So, I tried taking the rag joint off the gear box and rotating it there and it is also keyed. I have cross over steering so I just had to lengthen the tie rod to center the wheel. What a pain in the ass. My 70 has no problem adjusting the steering wheel.
07-28-2015, 09:50 AM | #3 |
I'm not sure if your '83 has the same tie rod/drag link setup my '78 has... But I needed to center mine as well...
With my truck, only 1 tie rod end is adjustable for toe, and the link between the gearbox and driver side knuckle is adjustable. It was a simple matter of adjusting the link between the gearbox and driver side knuckle to center the wheel. And it did not have any effect on toe.
Who needs a Hemi when ya got a Chevy! |
07-30-2015, 04:21 AM | #4 |
As above - adjust at the center drag link (4WD only):
Go under the truck and on the left hand side locate center drag link. It connects the pitman arm to the steering arm and is shown as item 17 below: It looks like this: If your steering wheel is offset (either CW or CCW) while traveling straight ahead - it can be easily trued up by shortening or extending the effective length of the link. Just glide to a stop (hands off the steering wheel). Your tires will be pointing straight ahead. Leave the steering wheel unlocked and loosen the clamps on the adjusting sleeve. Then with an assistant watching the steering wheel, turn the sleeve. The steering wheel will turn (either in the correct direction or not) if it gets worse, turn the sleeve the other way. It only takes about a 1/4 turn to move the wheel spokes about 45 degrees. This method doesn't affect your front end alignment. Nothing in the steering linkage changes - only the index of the steering wheel. Much easier than adjusting both tie-rod ends. |
07-31-2015, 08:00 AM | #5 | |
I'm not seeing the pictures but this advice is spot on. One of the easiest fixes there is. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-30-2015, 09:37 AM | #6 |
Yeah, if it were easy to center the steering wheel just by popping the wheel/nut off, everyone would have a centered wheel. Huge pet peeve of mine having the wheel not straight.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
07-30-2015, 03:56 PM | #7 |
can you post a picture of you steering shaft with you wheels straight ?
07-30-2015, 09:36 PM | #8 |
07-31-2015, 09:12 AM | #9 |
user # 2756
Yep, I adjusted the drag link. I was hoping it would be as easy as my 70.
