VSS and Muncie 4 speed
My plan was to use the existing 4 speed in my Corvette and stock bell housing and mate to a new LS 3
How will I adapt a VSS to the computer, or will I need a VSS? I understand I need a different pilot bearing to take up the distance with the Muncie trans and the LS 3 crankshaft and a truck (LS ) flywheel and clutch Engine motor mounts will change also
Re: VSS and Muncie 4 speed
I recommend using a VSS, You can run into Stalling issues without one.
A E38 ECM with a Manual Trans tune will need a 17 Pulse Per Revolution (Of the Output Shaft). These guys http://www.jagsthatrun.com/Pages/Spe...eedometer.html may have an Inline VSS pulse generator that will work. |
I think I have one of those on the shelf, I will check and see if it is the same as #3.
Will that one work for the ECU and "T" into the stock speedometer on the Muncie. Thanks Clinebarger
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 07-28-2015 at 12:57 AM. |
