07-29-2015, 06:54 PM | #1 |
Needing help on which ac bracket to use
I am putting in a LS motor with ece motor mounts and wondering if I can use lower ac bracket or do I need the mount in the upper position
07-29-2015, 07:56 PM | #2 |
Hollister Road Co.
Re: Needing help on which ac bracket to use
Most of the after marker compressors do allow enough room with the stock compressor. You can get the Holley LS brackets that look stock but hang the ac compressor up higher
07-30-2015, 05:49 AM | #3 |
I used Zoops on this LS in a 30 A truck.
07-30-2015, 10:23 AM | #4 |
I put an LS in my Chevelle and tried to use the low mount compressor. Even notched the frame to allow it room. Ended up calling Kwik and bought one of there kits with compressor included that mounted it up high on the passenger side.
"Life is too short to drive a boring vehicle". Later, Wayne |
07-30-2015, 12:26 PM | #5 |
Old member
LS1 brackets.
This is what I used in my 71 C10.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
