Old 07-30-2015, 07:23 AM   #1
greywurm
Rehooking up unknown factory air
My c10 came originally with factory air, but before I got it, someone switched out the 350 to the 250 i6 and an A/c compressor was not present, nor was the heater core hooked up.
I have since replaced the i6 with another 350 sbc, and wound up using a serpentine belt system I pulled from a 92 1500. I also took the compressor from the 92.
Now I want to hook up the heater core and see what all I need to do to get the A/C going, but I don't know where to start.
Can I use the original factory air components that should be there with the newer compressor? Is it ok to mix r12 and r134a components? Which kind of compressor do I have? I have seen a few types mentioned and I dont know which is which.
I put "should" in italics because I really dont know what all should be there to begin with, but from a novice, it appears complete (minus the deteriorated ducting that will need to be replaced and some hoses for the compressor to whatever).
Any help you guys can provide would be great. I really don't know where to start with this one.
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline   Reply With Quote
Old 07-30-2015, 08:18 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Rehooking up unknown factory air
The R4 compressor is completely fine for use with R134a. GM used it that way in '94 and '95 models.
You'll want to change the drier to a new one. The old desiccant in it is not compatible with R134a.
There's a chance the TXV (expansion valve) is stuck from sitting with no lubrication. The POA valve will need to a pressure adjustment to work effectively with R134a.
Likely, you'll want to change the hoses to the newer style (takes a little tweaking to fit with the R4 compressor) and while your at it, update the condenser to a more modern design.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-01-2015, 10:34 AM   #3
cooperhw
cooperhw's Avatar
good info. thanks.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-30-2015, 12:07 PM   #4
greywurm
sounds like it is doable but need to do some more research on these parts
Old 07-30-2015, 12:13 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Rehooking up unknown factory air
Give these guy's a call. They can help you.
Classic air. Any good local AC shop should be able to get you going. I bought the hose kit from Classic air but had a local shop do all the crimping and checked everything.
http://www.classicautoair.com/
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-01-2015, 09:49 AM   #6
greywurm
thanks andy, i emailed them yesterday and we are in touch.
Old 08-01-2015, 11:05 AM   #7
motorcritter
motorcritter's Avatar
You could also install an orifice tube/accumulator set-up like a 83-87, no POA to worry about, less plumbing to deal with. It looks like you've got nothing between the compressor and the evaporator- might as well update now. Also, get a newer style, more efficient condensor- it'll make a marked difference in cooling ability.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 08-01-2015, 11:29 AM   #8
Andy4639
Old member
Andy4639's Avatar
This is what I did in my 71.
a/c, factory air, serpentine belt drive
