Old 07-30-2015, 12:33 PM   #1
Longhornss
292 side cover Leak
Hello all does anyone have a good fix for stopping the side covers from leaking on a 292?
Longhornss is offline   Reply With Quote
Old 07-30-2015, 02:52 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 292 side cover Leak
Clean the block w/ degreaser and a high power spray so you can see if you still have a new leak. Remove lifter covers, scrape old gaskets off. Inspect for defects: bends, rips, flats, tears, etc. Get fresh gaskets -- neoprene not cork -- Fel-Pro or eqivalent. Put fresh gaskets on w/RTV on the tin side. When RTV is dry, replace on block and tighten [3+3] bolts. Do not overtighten. Check for leaks.
Old 07-30-2015, 06:11 PM   #3
GRX
GRX's Avatar
^^ that. Also ... lay the covers on a flat surface and look for deformities. Be sure the raised cross at the bolt holes is not pulled inward too far otherwise you will not get good even clamping pressure once installed.
Or ... you could spend $75 or so for a pair of cast aluminum covers. Much more rigid and less likely to leak than stamped sheet metal units.
GRX is offline   Reply With Quote
Old 07-30-2015, 07:32 PM   #4
68panelman
68panelman's Avatar
No leaks with "high tack" spray on cork gaskets for 25 yrs.
68panelman is offline   Reply With Quote
Old 07-30-2015, 07:36 PM   #5
68panelman
68panelman's Avatar
And no RTV goop to boot
Old 07-30-2015, 08:48 PM   #6
'68OrangeSunshine
You don't like RTV? There's a color RTV that's oil proof. Red, Blue or Black. Can't remember which one it is. Some people use RTV instead of a gasket, but I wouldn't use it alone.
Old 07-30-2015, 08:00 PM   #7
What have you tried? It's a simple removal, clean, and re-gasket job. Check plates for straight and that's about it.
Old 07-30-2015, 08:03 PM   #8
68panelman
68panelman's Avatar
Exactly ^^^, must be damaged covers
Old 07-30-2015, 09:02 PM   #9
68panelman
68panelman's Avatar
There's no need for RTV gasket, when using a cork askets a simple spray of high tack put on clean surfaces and you're done.
Old 07-30-2015, 09:05 PM   #10
68panelman
68panelman's Avatar
The only one I'll use is the copper for high heat
Old 07-30-2015, 09:26 PM   #11
GRX
GRX's Avatar
RTV to fill gaps from a warped cover. Not necessary for two perfectly flat mating surfaces obviously.
Old 07-30-2015, 10:02 PM   #12
I use the copper also. It will do what other high tack will do and not vice versa. I do use RTV when called for, which is usually a damaged or rough surface or lack of gasket fix.
Old 07-30-2015, 11:14 PM   #13
Longhornss
Ok I am feeling like I am missing something simple..... Have replaced gaskets. Originally with cork and then a neoprene type.
Checked for flat flanges and the over extended bolt holes.
Have used high tack, and permatex aircraft gasket sealer. Have even tried doubling the gaskets up.
No I have not used RTV that was my last resort.
Thanks guys for your suggestions I will check what I have been doing Aron and start again.
Old 07-31-2015, 05:09 AM   #14
Shaky
Six in a row makes it go...
Shaky's Avatar
Do I remember an o-ring or some little gasket under the bolt heads too? I doubt you're leaking from the bolts though.
Inspect the block surfaces. If I remember right, they are cast. Look for some obvious peak or valley in the cast iron.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-31-2015, 11:30 AM   #15
RichardJ
I'm not sure what the original seal looked like, but I put these bonded washers under the bolt head.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-31-2015, 03:57 PM   #16
'68OrangeSunshine
IIRC the OEM O-rings had right angle sides, rather than the circular profile of a normal O-ring. Just a flat rubber washer.
RichardJ's bonded steel washers would be a perfect upgrade.
Old 07-31-2015, 09:16 PM   #17
Longhornss
Hey thanks guys I will try again I have another set of side covers I will team and dbl check against my current covers.
Old 07-31-2015, 09:29 PM   #18
Let us know how it turns out
Old 07-31-2015, 10:12 PM   #19
Clavo106
SO FAR EVER ONES ADVICE SEEMs GOOD. for RTV I use the Right Stuff in a couck gun. u cant get more better sealant then that. as far as leaks I doubt but mybe a lot of blowby. or check if it leaking on the a aftermarket breather.pvc.
Clavo106 is offline   Reply With Quote
Old 08-01-2015, 06:29 AM   #20
Longhornss
The leak is contained to the side covers for sure. No problems with the PCV/breather.
I think I will get a new can of alpine green and shoot the extra set of covers ve have and try these with some new gaskets.....
Old 08-01-2015, 11:45 AM   #21
mk3barti
If you are using RTV make sure you give it time to set up. When I did my covers I attached the gaskets to the covers, let it set up, then put them on the truck, let them set up, tightened, then drove. Took over a day to let everything dry but I have no leaks. I failed to do this on my valve cover gasket and it leaked right away.
mk3barti is offline   Reply With Quote
Old 07-31-2015, 10:14 PM   #22
Clavo106
Forgot to add throw baby powder and see where is runs off to.
Old 08-05-2015, 09:29 PM   #23
Squareforceone
Squareforceone's Avatar
ttttt
Rust is better than rice.
Squareforceone is offline   Reply With Quote
