Old 07-30-2015, 12:38 PM   #1
siggyfreud
siggyfreud's Avatar
Sway bars - 60-66 or later with front end swap?
Hey all,
I have a 66 GMC, but swapped in the front crossmember and all the components from a later-model Chevy to get 5-lug discs. Might be a dumb question, but do I want a sway bar from the later generation, or one for a 60-66? Since it bolts both to the frame and suspension I'm not sure which is "correct", or if both actually would work.
Cheers!
siggyfreud is offline   Reply With Quote
Old 07-30-2015, 01:20 PM   #2
Clyde65
Clyde65's Avatar
Re: Sway bars - 60-66 or later with front end swap?
later but you could also do aftermarket for a larger diameter one.
http://www.classicperform.com/Store/...ck/6372SBK.htm
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-30-2015, 02:06 PM   #3
frankslagoon
It's probably hard to find a stock 66 or earlier bar. I used a later one and drilled the holes. if I had holes in the A Arms already like yours I would start with the bar that fits em. Mines a stock 1 1/ 16 I think. My brother drove the truck a and freaked out it drove sooo much better. I also put a Camaro rear bar on but not sure how much we really need em in the rear.
frankslagoon is offline   Reply With Quote
Old 07-30-2015, 02:42 PM   #4
PGSigns
PGSigns's Avatar
Mine is also off the donor 81 truck. Works good.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-30-2015, 08:32 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mines' got a 72 crossmember, and run pretty much the same setup as Frankslagon. I think my brackets are different, but it functions the same.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-30-2015, 08:44 PM   #6
c20 diesel
took the sway bar & brackets off a 87 one ton 1 1/4 inch bar. $20 dollars
salvage yard. had to drill holes in 64 frame & lower controll arms. I was told 65 & 66 Had holes already drilled . do not know about 65, my 66 has factory sway bar bracket holes.
c20 diesel is offline   Reply With Quote
Old 07-31-2015, 12:36 AM   #7
Captainfab
60-66 Nut
As far as I know the '63-'66 front sway bars will interchange with the '67-'87 sway bars. The '73+ C20 Custom Campers and C30 have the biggest factory sway bars.
Old 07-31-2015, 09:22 AM   #8
siggyfreud
siggyfreud's Avatar
Awesome info! Thanks all. Will likely go the aftermarket route when the time comes.
Old 07-31-2015, 10:46 PM   #9
T and S
T and S's Avatar
I picked up a used bar for $40, the bushings are still in good enough shape to use. Bar measured 15/16", but will be better than nothing.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 07-31-2015, 11:19 PM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
so I have 2 different ones I could use.. one is off a 73-87 1/2 ton and measures 1 to 1 1/8, the other is off a 86 3/4 ton suburban and looks to measure 1 1/4+ , is there a reason to or not to use the heavier bar?
Old 08-01-2015, 01:22 AM   #11
Captainfab
60-66 Nut
I see no reason to not use the heavier bar, especially on your CC.
Old 08-01-2015, 08:49 PM   #12
HumphreyMurdoch
HumphreyMurdoch's Avatar
Not to hijack the thread, but what about 60-62's with the crossmember swap? Will the raised brackets for the frame work that ECE sells?
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 02-06-2016, 08:12 PM   #13
dracko
dracko's Avatar
I have a '64 that I just installed an '87 crossmember on.
Wondering if any of the holes in the frame rail can be used to mount the stock height brackets? or if I need to drill the 4 holes with the bar attached to the A arms and suspension compressed?
I've heard the crossmember rivet hole works but like to hear from somebody that has done it. Thanks!
dracko is offline   Reply With Quote
Old 02-07-2016, 01:19 AM   #14
DakotaKid
I have a 62 with a 74 Crossmember, I am using the 74 sway bar with the mounts from LMC for the frame side. Stock 74 Am mounts with bushings. Works perfect.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 02-07-2016, 08:56 AM   #15
dracko
dracko's Avatar
Okay thanks, do you recall if you drilled out the rivet holding the radiator support brace and used the hole to mount the frame mounts? Or did you drill 4 new holes?
Old 02-08-2016, 12:48 PM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
I swapped in the 78 front suspension and used the stock 78 front bar after drilling the frame bracket holes. It fits and works perfectly. Back when I had the stock suspension, I ran an aftermarket Mustang V8 bar up front with heavy bolted on brackets attached to the original lower suspension pieces. Both worked fine, but the heavier 78 bar works even better.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-08-2016, 01:51 PM   #17
dracko
dracko's Avatar
Okay cool thanks, I grinded off the rivets for the rad support crossmember but the brackets ended up sitting further ahead so I didn't use the holes. Did manage to use the elongated holes that were further ahead on the bottom of the frame rail. Seems very solid now.
