08-04-2015, 10:37 PM | #1 |
CPP disc brakes?
Has anyone bought the full front and back disc brake kit from CPP? Looks like a good deal to me, at least better than buying separate parts from LMC. Looking to get the kit really soon.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
08-05-2015, 08:08 AM | #2 |
Re: CPP disc brakes?
I haven't worked with the entire kit before only the rear disk and it works as intended.
The rear parking brake is important so don't buy a kit that doesn't have that option. If you are going with big wheels 20" or larger then CPP sells a "modular" drop spindle that brings in the wheel 3/4" on each side so that you won't have clearance issues with the fender and will also give you a little bit more lip on the wheel and who doesn't like more lip, I haven't heard of another brand that offers this feature. Last edited by Xeen; 08-05-2015 at 08:28 AM. |
08-05-2015, 12:57 PM | #3 |
I'm finishing that whole setup right now. Front went on seamlessly and quickly. Rears are a bit more time-consuming. Some threads in this forum discuss the issues on pad thickness and caliper mounting alignment. Not a big pain, but need to finesse them sometimes. While the overall quality is good for the dough, make sure the rotors don't have casting flashing in the cooling ribs. I had to punch out some of the flashing on the fronts. Good luck.
Phil |
08-05-2015, 01:06 PM | #4 |
Old member
I bought the CPP rear disc brake kit and after I figured it out it's OK. I was hoping it would be very noticeable deference in the stopping of my 71 with 20" wheels but after finishing it, it's not much better than with the drums!
The kit was a pain to install also because they don't tell you you may not need the spacers for the calipers. I had to take everything back off the passenger side. I called there help line several times. The rear brake hose they send want fit the tee at the rear end either. Adjusting the rear brakes is a real joy! Here is my thread on my install. http://67-72chevytrucks.com/vboard/s...d.php?t=647684
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-28-2016, 12:28 AM | #5 |
I'm going to bump this.
I have their big brake kit at each corner. Went in smooth but I still need to shim the passenger side like Andy mentioned. The truck stops awesome. Takes a lot of pedal pressure though, almost like they are manual but not :/ I also have the booster that came with the "kit". what I'm fighting now, with just over 900 miles on them, is the constant squeaking/squealing from what sounds like more than one corner. LOUD, like I can drown out a metro bus or semi truck. The warmer the brakes get, the louder they are. It has done this from day one probably. Also, the brake dust is crazy. @ 900 miles it's the most dust I've ever seen
'68 C10 SWB '85 K30 Blazer |
