Related or Not?
So I have 2 issues. They should be related I would think maybe not. First thing is at the fuse box. I do not have any power to the ignition spade at the fuse box. I have key on power to everything else but the ignition spade at the fuse box.
Second is my turn signals have stopped working everything else related to taillights work. So I have determined with testing I need a new turn signal switch. So would my turn signal switch cause problems with the ignition spade on the fuse box? Or a these separate issues. I just think it is funny that the turn signals stopped working and I have no power to the ignition spade on the fuse box. And if they are separate why no power to ignition spade at fuse box? And yes I texted with key on position. Or is this a ignition switch issue. Everything works like normal just the 2 issue I posted above. Last edited by RodsGreen10; 08-05-2015 at 04:33 PM. |
Re: Related or Not?
Found it! 1 damn little 15 amp fuse popped. Replaced life is good again.
