08-06-2015, 09:33 PM | #1 |
How can I tell what ball joint my 2.5" drop spindle uses
I got my 67 C10 truck with 2.5' drop spindles
I do not know what brand they might be. I do not know where they were purchased. I would like to know how I can figure out what year ball joint they use I am buying new A arms and they can come with whatever year Balljoint I need. The only issue is I do not know which one to choose. Is there a way to tell? Thanks so much for any assistance you can give.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-06-2015, 09:46 PM | #2 |
Re: How can I tell what ball joint my 2.5" drop spindle uses
The brand and model number of the drop spindle will be stamped on it, get out your flashlight and find it and then call the manufacture and ask what ball joint you need.
08-06-2015, 09:48 PM | #3 |
Thanks!!!! will do!
08-08-2015, 05:19 PM | #4 |
Wondering if you found out anything. I ordered mine from CPP but they were Westin brand. The spindle setup is for 73-87 brake stuff but when I tried to use the 68 balljoints they would not seat all the way down on the top. Maybe I need 72-87 ball joints? And if so will they fit in the stock 68 a-arms? Anyone know?
08-08-2015, 06:50 PM | #5 | |
Thanks for all the info guys!
08-08-2015, 05:42 PM | #6 |
Moderator
Take your spindle to a local auto parts house and match it up. A lot of the spindle companies have the same casting numbers that span several years of trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-08-2015, 06:01 PM | #7 |
Seafoam68, the drum brake and disk brake systems use different ball joint's, in 1967-1970 the standard braking system was drum and the ball joint stud is larger in diameter therefore if you try to install it into a 1971-72 disk brake spindle it won't seat.
I don't know about 73-85 spindles. |
