08-07-2015, 10:27 AM | #1 |
Door won't lock from outside
I have a recurring problem with my driver door lock where it will not lock from the outside. I have paid a locksmith to come fix it three times and a month or two later the problem comes back. Anyone have an idea of what is causing this?
08-07-2015, 10:48 AM | #2 | |
The Older Generation
Re: Door won't lock from outside
Have you lubed the door latch and lock mechanism? Roll the window down and spray some good penetrating oil (not WD-40) on the back of the lock and on the latch. You can see the latch and back of the lock inside the door with the window down if you use a good light. LockDoc
08-07-2015, 11:09 AM | #3 | |
Frustrating - I keep having to lock it from inside and climb through the passenger side to lock up my truck. |
08-07-2015, 12:55 PM | #4 | |
Do you have more than one key? If so does it do the same thing with all of the keys? LockDoc
08-07-2015, 01:35 PM | #5 | |
It was worth asking on here in case someone else had the same trouble and discovered the cause. Thanks for the help! |
08-07-2015, 10:52 AM | #6 |
Do you live on a rock/gravel road?
Posted via Mobile Device |
08-07-2015, 11:03 AM | #7 |
No, in town
08-07-2015, 11:38 AM | #8 |
I had a similar issue and I did what LockDoc is suggesting. I used aero kroil. That stuff works great
08-07-2015, 01:41 PM | #9 |
the next time it wont lock, open the door and try locking it with the door open. its a common problem on this site. the door has too much pressure on the lock mechanism...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
08-07-2015, 03:15 PM | #10 |
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
