08-08-2015, 11:11 AM | #1 |
Pic Of my 65 Chevy frame
Here is a pic of my 65 chevy Frame with all the 72 Blazer Front and Rear 4x4 axles and brackets bolted in place making my 2wd into a 4x4
08-08-2015, 12:49 PM | #2 |
Re: Pic Of my 65 Chevy frame
Did you leave the 2wd crossmember in place?
08-08-2015, 02:23 PM | #3 |
Yes I did and added bump stops to the bottom , also to retain my engine mounting brackets.
08-08-2015, 03:38 PM | #4 |
Picture is very grainy for me. Hard to see what's going on.
Posted via Mobile Device |
08-08-2015, 07:43 PM | #5 |
little better pic
08-08-2015, 10:22 PM | #6 |
Is the crossmember going to interfere with the front driveshaft or anything else when the suspension cycles?
08-09-2015, 01:06 AM | #7 |
60-66 Nut
You're going to have a problem with the front differential hitting the 2wd suspension crossmember. Why not just use the engine crossmember from the Blazer?
08-09-2015, 12:30 PM | #8 |
I don't have the crossmember from the 72 blazer. will any other year blazer crossmember work if you all know? Thanks
08-10-2015, 12:58 AM | #9 |
60-66 Nut
It doesn't have to be from just a Blazer......we're working on Chevy's here not F*&ds. All '67-'72 K5,K10, K20 and K30 engine crossmembers are the same. You could also use the engine crossmember from a '73-'87 K5, K10, K20 or K30, but some modification will be needed.
08-10-2015, 07:11 AM | #10 |
Thanks Capt , Are they bolted in or Riveted in ?
08-13-2015, 08:12 PM | #11 |
1961 crewcab
that looks like the complete unit
you could also source one out of a 73-87, I used one in my sub, had to cut the mounts down just a little , which you can see in the pic
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-13-2015, 10:58 PM | #12 |
1961 crewcab
mine has a 4 inch lift, and I don't plan on using it for anything other than winter transport, so I didn't feel that it would ever move enough to hit the bumpstop.
however I did save all the bumpstops off the 87 , there was one that the diff would hit, and another 2 for the spring pads...
