![]() Join Date: Sep 2005
my ls swap died...
so i swaped in a 4.8 4l60e into my 71 its been runnign for a while now and ive been battleing p0171 and p0174 system lean codes, i cleaned the massf low and checked for vacumn leaks but did not find any. drove it codes came back sometimes it would not idle so i replaced the mass flow with an ac delo reman, on my way home ti started bucking and jerking and then stalled out and wouldn;t start back i think i lost the fuel pump in the tank an ac delo ep381 with corvet filter
Re: my ls swap died...
Did you check fuel pressure when you were getting lean codes?
A failing/weak pump or other restrictions can cause fuel pressure to go low. I believe 58 psi is the minimum to keep everything happy. CT |
I did not but i pretty sure now it was fuel related
meowMEOWmeowMEOW
Those are whole-bank codes, so ya its most likely that something in between the tank and rail died. Luckily, the culprits are only the pump, reg, or filter...and all are pretty simple fixes.
Do the easy stuff first like checking that the filters aren't clogged (or too small), and that nothing is kinked/damaged. Then, I'd take a look at the feed hose on the in-tank pump from the pump motor to the sender. Its only 3" long, and has been known to split...especially if the wrong hose got used by mistake. As long as it wasn't also seeing a ton of heat, its most likely that your lean condition didn't damage anything...hopefully the ECM killed protected you from that. If you scan it now, how many codes do you get?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Its not ready only codes as p0650 mil control circuit but that cause i dont have the engine light wired. It died like 4 miles after mass flow replacement
meowMEOWmeowMEOW
Unlplug the maf to force-fail. The ECM will idle you off of speed density and you should be able to see if there is an immediate change.
It will not sTart with maf unpluged or pluged in. There is no fuel at the saddler vavle
meowMEOWmeowMEOW
Current at the pump (pump even turn on? you should hear it prime, dpending on how much gas is in tank muffling it).
Couod not hear pump prime when it died but i havent had a chnace to check for power at pump or relays
im interested to see the answer to this one.
Me to it is sitting at a friends shop it died as i 2as passing his shop. But i havent had anytime to work on it with my work schedule he said he would look at it when he could if i couldn't, but be has paying customers and they have to come first plus i told him i wasnt in a hurry
I am sure the problem will be resolved, easily. i haven't seen many LSxs die unless the engine falls apart internally, like piston rings, cylinder heads, or a bad crankshaft. they usually run forever. most of us pass them on to the next owner, when we decide to sell them.
meowMEOWmeowMEOW
We just rebuild em if they pop. Not much can really "grenade" on these unless your making 600+whp on stock internals. Con rod bolts, lifters, rocker bearings are the only things that ever really self destruct (unless the oil pump went, which isn't your problem on this one).
![]() Join Date: Jan 2015
which brand filter/reg unit? some are known to poop out early
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
#15 |
Wix 33733 or soemthing like that its the vett filter i used an ac delo fuel pump ep381
#16 |
![]() Join Date: Jul 2009
Mine presented with those same symptoms one day. I pulled the vacuum hose off of the fuel pressure regulator and gas ran out of it. Replaced the regulator and she ran like a fine watch once again.
#17 |
Mine does not have a regualtor in the rail it is a retrunless system
#18 |
Sounds like you're using the Corvette filter/regulator combo that fixes pressure at 58psi. You just need to verify that you are getting power to your fuel pump, and that it's pushing fuel. If it is, you likely need to replace your filter/regulator. At that point you can do a pressure test and see what it is.
If you're not getting power to the fuel pump its an electrical issue. If you are getting power but no fuel, likely the fuel pump went bad (assuming ground is good). |
#19 |
meowMEOWmeowMEOW
I'm still thinking that feed hose from the pump to the sender is popped. Soooooo common on in-tanks.
#20 |
truckdude239, take some personal time off from the job and work on your truck. if you need an excuse, tell your supervisor that a close member of your family is really, really sick. he/she is having some real complications with his/her mobility. this person really needs your assistance, and you want to be there, for them, during their time of need. truckdude239, don't go too much into the details. call your supervisor from your cell phone, and speak slow and sadly during the call. if you are a bad liar, rehearse this a couple of times, before you actually make the call. if you need to, look at a few episodes of "The walking dead". Imagine rick grimes just wrecked your truck, killing zombies. "yeah", that should do it. sad, sad, sad. a c10 destroyed for a movie prop. that would really make me sad.
#21 | |
Yea that wont work
#22 |
truckdude239, to most of us on the forum, our trucks are members of our families. My previous post was intended for laughter. It hurts me when my truck isn't running properly. If work is a priority, by all means, be there everyday that the doors are open. Every once in a while, I use personal leave from the job to work on my trucks. Its my therapy. Dr. C. says so (I see a therapist). I took a week off from work, to complete an engine swap on Choppy. It was a very memorable week. I loved every minute. the wife and kids were away, at school and work. It was just me and choppy. Choppy is the son, friend, and brother I never had. He is always there to lift my spirits, console me when I'm alone, and teaches me life's lessons. Vroom, Vroom. Damn I love my truck. I feel a burnout coming, when I get off from work.
#23 | |
meowMEOWmeowMEOW
Whether it be a "living" family, pets, a truck, stuffed plastic maniquins with realistic private parts or something like art...we all have that thing that matters most to us. I think what Dec is really saying tho, is that unless you bear down and make time, the problem won't be solving itself any time soon. Most of the idea's we've thrown out could be knocked off the list in a few evenings, so don't convince yourself you don't (or can't) make time to fix it. Don't get discouraged, and just do down the list. We'll be here whenever you get around to it.
#24 |
![]() Join Date: Aug 2004
I am in a similar pickle as Truckdude, I cant take time off for my truck hobby, would love to but cant. I work on my truck about once a month when I have a Saturday off of everything. I get a bunch done ( or this is what I tell myself) but just never enough time to do everything needed.
Most of my vacation time is spent ON vacation ( two weeks a year sometimes) and the rest of my time is spent helping my elderly parents and/or my kids. Oh and then there is work.....I gotta do that, right? Br3w, your a funny guy! that was classic!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#25 |
Well it lives they traced it back to a bad computer ground which is weird cause i had the computer grounded but they added 2 more grounds and it fired right up had 58 psi fuel pressure.
