Old 08-11-2015, 06:11 PM   #1
tony2tall
Non-EFI Boyds tank converted to EFI
Anyone else do this? I found a post by vannatta20 doing this, but was wondering if anyone else has attempted and their feedback.
http://67-72chevytrucks.com/vboard/s...d.php?t=556873
Seems like a good way to save quite a bit of money versus the additional $300 from Boyd for an EFI setup.
tony2tall is offline   Reply With Quote
Old 08-12-2015, 09:45 AM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Non-EFI Boyds tank converted to EFI
I converted my non-EFI boyd's tank to EFI. If I had it to do over, I would spend the additional $300.
Willie Makeit is offline   Reply With Quote
Old 08-12-2015, 10:18 AM   #3
tony2tall
Why is that? Did it not work well, or just a pain in the butt?
Old 08-12-2015, 10:45 AM   #4
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I'm converting mine as well, using a kit like this that I got for about half the cost.
http://www.summitracing.com/parts/clp-ufpk-fi
Since they construct all the tanks with the same internal baffling, should work out fine. That's the plan anyway..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-12-2015, 08:50 PM   #5
Majourlittle
Oh boy that's a lot for that pump setup. Try these guys. I just bought all of that setup for much less.
http://www.tanksinc.com/
BTW, Hi and not affiliated with the link above.
Majourlittle is offline   Reply With Quote
Old 08-13-2015, 06:56 PM   #6
siggyfreud
siggyfreud's Avatar
I'm sure those kits get the job done, but keep in mind that at least half the extra cost is the Aeromotive fuel pump they put into the EFI verison. Not sure what type of pump some of those kits come with, but the few examples I have seen appear to be generic-no-brand pumps. Whether that's good, bad, or immaterial is your call as I haven't used them, just thought it was worth noting.
siggyfreud is offline   Reply With Quote
Old 11-19-2017, 12:51 AM   #7
Jkmyers84
Anyone make an adaptor for a Boyd tank to run a stock vortec pump? Seems the aeromotive pump adaptor looks like something to work off of
Jkmyers84 is offline   Reply With Quote
Old 11-24-2017, 12:09 AM   #8
vannatta20
vannatta20's Avatar
The good thing about running a factory AC delco pump is it is dependable and does not require a baffle. It has a bucket that the fuel pump resides in and uses a venturie system that keeps the bucket full of fuel. You can use a truck pump and cut the rods down to save some money$$
https://www.amazon.com/ACDelco-Assem...1%2C3937584011
vannatta20 is offline   Reply With Quote
Old 11-24-2017, 10:15 PM   #9
Jkmyers84
On the new Boyd tanks how would you make something to use the stock pump lockring?
Old 11-27-2017, 11:00 AM   #10
vannatta20
vannatta20's Avatar
We just tapped the aluminum tank to hold the lock ring tight. If you guys want I can have some rings cut from a plasma table. Then you just bolt the ring down.
Old 11-27-2017, 06:10 PM   #11
Jkmyers84
Awesome
Old 12-02-2017, 09:12 PM   #12
Jkmyers84
Details?
Old 11-29-2017, 11:24 AM   #13
ls1nova71
ls1nova71's Avatar
I like the GM fuel pump/buckets too, they work great. As a side note, not sure how deep the tanks you're using are, but a Tahoe pump from the same year is shorter than a truck one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
