Old 08-14-2015, 03:26 PM   #1
dwreck812
Help identify my sbc 350
I've checked the engine up and down all I can find near the bell housing is a "xj4826" and this stamp location under the distributor I've also pulled valve covers and found nothing
dwreck812 is offline   Reply With Quote
Old 08-14-2015, 04:15 PM   #2
MARKDTN
Re: Help identify my sbc 350
Need a photo of the VIN pad. Looks like a 350 1-pc seal block.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-14-2015, 04:29 PM   #3
dwreck812
Well I'm either gettin 10243880 or 10248880
Old 08-14-2015, 04:53 PM   #4
summitflier
summitflier's Avatar
Anything on the passenger side front of engine? Right beneath the head.
(Often covered up by the alternator).
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 08-14-2015, 05:10 PM   #5
dwreck812
Nothing on passenger side front bUT right below distributor I found 10243880
Old 08-14-2015, 05:26 PM   #6
Clavo106
10243880
96-up
350
2 & 4-Bolt Vortec Roller
Clavo106 is offline   Reply With Quote
Old 08-14-2015, 05:35 PM   #7
dwreck812
Is it worth keeping in the truck or would a 5.3 be better and if it's roller cam could it be a zz4
Old 08-14-2015, 05:58 PM   #8
leftybass209
leftybass209's Avatar
If it's not running, and you don't already have a bunch of purchased accessories for a sbc, an ls will give you a,more usable power curve, higher rpm usage, better gas mileage, longevity, and better cold starts.
I don't think an ls looks as cool as a sbc, and the overabundance of these swaps has become both boring and nauseating, but it's undeniable that it's a popular swap for an antequated small block, and when my engine finally crap out, I'm going ls as well.
leftybass209 is offline   Reply With Quote
Old 08-14-2015, 06:27 PM   #9
MikeB
MikeB's Avatar
I think the 880 block can date back to 1986. It may or may not have had a roller cam from the factory. But even if it doesn't, it may be machined to accept a roller cam retainer plate and roller lifter "spider" bracket. Got that?
Also many 880 blocks were not machined to accept a mechanical fuel pump and pushrod. And the block could have 2-bolt or 4-bolt mains.
So, all you really know is it has a one-piece main seal.
And BTW, I have found these to be very good castings, even if they are hecho en Mexico.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-14-2015, 06:43 PM   #10
hugger6933
I'm gonna use a educated guess[rebuilding hundreds of those trucks as my education] and say it is a 87-94 TBI motor and it is gonna be machined for the roller but have a hyd cam. The heads are gonna help a ton if it has 4 bolt holes [for the intake] or 6 bolt holes for the inlet per side. I dont know how prices are in your region but the LS type motors at my place[this is NOT an ad for sale as I won't sell on here since I('m not a paying member and it is not fair to those who do]sell for around $450 for a 4.8 and 600 or so for a 5.3. Complete drop outs with wires PCM and trans can be had around a grand. Of course the 6.0's are a little higher cause of the demand and availability.The small block is the cheapest read less expensive way to go as your truck is most likely set up for it. The stuff that it takes to make one run in there[LS] is gonna cost but it is getting cheaper all the time. Jim
hugger6933 is offline   Reply With Quote
Old 08-14-2015, 10:42 PM   #11
dwreck812
So would it be better to keep the 5.7 tbi engine or put the efi 5.3 in?
Old 08-14-2015, 11:03 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The 5.7 will fall right in. The 5.3 not so much.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-14-2015, 11:06 PM   #13
dwreck812
The 5.7 is already in it whomever had the truck before me didn't wanna wire the truck to be tbi so they put a carb on it but I'm either going to go with fast e.f.I or back to tbi if I decide to keep the 5.7 in it
