Old 09-09-2003, 09:51 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Question Q about 60-66 cab to frame grounding
Where on these trucks (63 specifically) would the grounding strap be located from the cab to frame???
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 09-11-2003, 06:11 PM   #2
kennyw
N9PHW
kennyw's Avatar
Usually found between the firewall and engine then the engine is grounded to the battery and frame.
"I got it one piece at a time and it didn't cost me a dime..."
kennyw is offline   Reply With Quote
Old 09-12-2003, 10:30 AM   #3
SWINGSAX68
SWINGSAX68's Avatar
thanks, isn't there one that is below the cab around one of the cab mounts???? I know my 68 has one from the cab above the passengers front cab mount which connects to the frame directly below it. None of those on a 63???
-Roger
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 09-17-2003, 04:15 PM   #4
kennyw
N9PHW
kennyw's Avatar
I have never seen a ground strap directly between the cab and frame on any of the 15-20 trucks I have worked on/parted out. Only thing I have found is the strap between motor and body.
Old 09-17-2003, 09:48 PM   #5
blood
Talking
i dont think they use to realy care about grounding much back then
As the curtain calls, and the cast recedes, I am all that ever was and all that ever will be. In wither and repose this frayed chapter now does close, and fade into neon black
blood is offline   Reply With Quote
