Tire Fitting
I'm building a 72 c10 and putting 295/45/20 tires on the back. Does anyone know if I can put the same size on the front? If not, what is the biggest size I can put on the front with a 20 inch wheel?
Re: Tire Fitting
I'm running a 255/45/20 in the front. I do have an air ride set up but I drive it at a height of about a 2-3" drop and have no issues.
Re: Tire Fitting
I believe that 255 is as wide as you can run, especially with a drop.
1969 Chevy CST/10 396, PS, PB, A/C |
Re: Tire Fitting
I have 275/45/20 front and rear. Front with a spindle and 1" drop spring snags a fender bolt every once in a while but my springs and Monroe shocks are a little soft.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
