![]() Join Date: Jan 2015
Should this just slide out
Pulling the hatch handle off. Have all the screws, c-clip and hardware removed. Soaked it down with BP Blast. Should the handle and shaft slide out of the rod holder and spring?
![]() Join Date: May 2011
Re: Should this just slide out
yep but I had 2 that I just had to give up and cut the shaft with a cutoff wheel on a dremel. I even made a puller one time and it ended up messing the plate up that held the rods.
I thought the whole unit would come out of the hatch. Isn't there a couple of roll pins you can punch out to disassemble the handle?
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
See link below but you still need to remove the rod mechanism before it will come apart.
http://67-72chevytrucks.com/vboard/s...d.php?t=509656 |
I just fought 2 of these that were acting the same way. In the end what worked was heat. The only problem is that 40 year old fiberglass doesn't like open flames. Find something to protect the fiberglass and use a torch with a small controlled flame, and you will eventually work it out of there.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Just be careful not to damage the spring with the torch
![]() Join Date: Jan 2014
I'm currently fighting this right now. Any new tips or tricks? I have one soaking in some WD-40 right now.
![]() Join Date: Jan 2013
I have 2 of these to do also, hope I have better luck. Might try a arc welder. Ground the handle and stick the rod on the shaft and watch it glow. After it cools the rust might be loosened or the shaft might shrink??
Carpe manana
![]() ![]() Join Date: Dec 2010
Sub'd...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Dec 2002
I have gotten a few free with a C clamp put one end on the shaft and the other on the tab/ear that has the hole for the lock rod. You are essentially pressing it out
Member #1049
I have found (After destroying several) that the only way to get those rusted ones apart is heat and penetrating oil (PB blaster, Liquid Wrench, Acetone/ATF etc),
I take a soup can and cut it down to fit in the recess, unwind the spring off the unit (heat will destroy it too), put the soup can in and behind the handle (To protect the fiberglass). Liberally soak the shaft with penetrating oil, use a small torch to heat it up. apply more penetrating oil.. Walk away and let it cool down. Apply more oil.. heat again, add more oil then clamp a small puller and add some tension, heat again.. more oil, more tension... ADD lots of patience!!.. keep repeating those steps and eventually they do come off.. |
#12 | |
K5drive
#15 |
Please let me know. I've been looking at spring makers online too. I may have found a custom spring maker that can make these types of "torsion" springs. Does it just slide out when you disassemble the hatch assembly? They need an actual spring to copy.
#16 |
I have never looked for the springs but one place you might search is garage door lock places. That's what the lock design stuff comes from or camper shell tops. I say garage door because I installed them in summers while in college. The locking mech had a spring on them that was similar to kick the lock back when you turned the key. Just a thought
