08-20-2015, 02:51 AM | #1 |
meowMEOWmeowMEOW
Budget VS Longevity; Stainless Mufflers & Exhausts
My project evolves constantly, but gets a big change every 3-4 years. I just did my new heads and headers on the truck, so its time to re-do my exhaust setup again.
I generally feel that stainless is the "final" solution for any long term enthusiast. If your equipped to weld it and can afford it (and your setup is finalized), then SS is the best choice all around. Being as my setup changes, I generally opt for mild steel. Its available everywhere, easy to weld with anything, and in summer-use hot rods etc, it lasts plenty long. So what I'm really wondering is; how do you guys feel about mild vs stainless for mufflers specifically? Since my headers are mild, and my pipes will most likely be too. But I'm debating mild vs stainless on my bullet mufflers, both DynoMax and Magnaflow. Partially I think the extra cost might be a waste on a a mild steel exhaust...but part of my also thinks that the stainless mufflers build quality might last through more than one era of changes. My current stainless Magnaflow bullets are probably around 7-9 years old. and one JUST got the "rattles" inside or I'd consider reusing them on this setup. So, a little discussion on the topic in general, as well as my particular query; you may proceed gentlemen.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-20-2015, 11:09 AM | #2 |
mini truck racer
Re: Budget VS Longevity; Stainless Mufflers & Exhausts
I have Stainless Borla straight thru mufflers with aluminized pipe . Problem is none mandral bending the big pipe .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
08-20-2015, 11:40 AM | #3 |
Registered Truck Offender
One problem with stainless is it will rust anywhere it comes in contact with a ferric iron / steel. So you need to make sure your hangars, mufflers etc are all stainless. AND TIG weld or at least MIG with stainless wire. Food grade stainless is purged of air on the inside, then TIG'd. Keeps the inside of the weld as pretty as the outside. You'd be surprised how the inside turns out of not 'process' welded like this.
Is it worth the $ and effort???? ,, IMO ABSOLUTELY if your willing to spend to do it right. If for no other reason than that 'ring' of an exhaust note that seems to come from a stainless system. Have 3" stainless borla's on 2 vehicles now.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-20-2015, 12:45 PM | #4 | |
meowMEOWmeowMEOW
What weird is that right now I have the (old) Mangaflow SS mufflers, but a mild steel exhaust and never had a reaction (galvanic?). I think the inlet and outlet on the muffler are actually mild steel, and the welded with 309l or Silicon bronze or something, since the center section is definately stainless.
08-20-2015, 02:03 PM | #5 |
It's Better With Nitro
Having worked at a couple of header manufacturers and built many headers myself, I've always gone with mild steel and used a ceramic metallic coating - I have built stainless headers for specific customer requests. My reasoning for going with mild steel on my own stuff is the extreme heat cycles in racing that can contribute to heat-related fractures/failures in the more brittle materials and I don't live in a high humidity region. I see a lot more stainless headers develop cracks. My headers on my old Super Gas car showed no signs of corrosion or damage after 20 years of racing. My radiator hoses were made from the same mild steel tubing and were also ceramic metallic coated, and showed no signs of corrosion being subjected to water. I do run stainless mufflers on all of my hot rods, particularly Borlas. Stainless from the muffler back will help with the longevity of the system as you were asking about.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
08-24-2015, 03:34 PM | #6 | |
i agree with mild/aluminized pipe. moisture seems to collect in mufflers, and for that reason i like using stainless in that area. i used coated headers on my ls build and absolutely love them, the rest of the exhaust pipe is aluminized and painted with hi-temp rattle can paint. after almost 4 years the headers still look new and the exhaust pipes have some minor rock chips etc. ceramic coatings get my vote over stainless for sure.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
08-20-2015, 02:05 PM | #7 |
Moderator
If it's not going to be a daily driver, and will not see driving on winter salted roads, regular aluminized pipes and mufflers will last just about indefinitely. The full dual exhaust on my 71 was put on in 1991, and is still shiny.
08-21-2015, 01:19 AM | #8 |
meowMEOWmeowMEOW
Vin, is that sort of coating something a regular powdercoat shop would handle? Do you have any idea what it would cost? Due to my short run, my whole exhaust including headers has come in way under $800, so I'd definately consider coating it.
08-21-2015, 10:33 AM | #9 | |
This is the sterling on the headers and exhaust tubing for my C10: Found a photo from a fellow Pontiac friend that shows the cast iron color:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 08-21-2015 at 10:41 AM. Reason: added photo |
08-21-2015, 10:55 AM | #10 |
motor exploder
I went the same route Vin63 did on my '69 - ceramic coated headers (Hedman Elites), Borla XR1 ss mufflers, and used a 3" Flowmaster mild steel/aluminized kit that I mig'd at home, then had the exhaust system ceramic coated (matte black) at my local powder coater. They said it was good for 1200*. Not a daily driver, just a money hogging toy. Other than the mufflers turning a little bit of a gold color, everything still looks good.
Now, on my daily driver ('05 GMC 1500, 5.3L) I have SS longtubes, aluminized pipe and mild steel mufflers - Flowtech Terminators. It's been on for 3 years now, the pipe and headers still look nice, but the mufflers already looked ragged out.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
08-21-2015, 08:06 PM | #11 |
meowMEOWmeowMEOW
Vin- those finished looked like the turned out really nice. That cast finish would be killer on a sleeper, make everything look "old"
Both the black and the silver look like good options as well. I ended up ordering all the stuff in mild anyway, so I might have to get mine coated.
08-21-2015, 08:36 PM | #12 |
I work in an exhaust shop. Stainless is being eaten by this garbage fuel we have. I personally wouldn't bother with stainless. You can do 2 or 3 aluminized systems for the cost of 1 stainless system. Stainless doesn't last indefinitely. Factory stainless pipe rots out regularly. Stainless is also brittle and prone to cracking. Stainless is a pain in the @ss to bend without a mandrel bender.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-22-2015, 05:08 PM | #13 | |
meowMEOWmeowMEOW
I agree with you about bending/flaring/working stainless and its propensity for cracking.
But I'm curious about the "being eaten by fuel". Is that anything to do with the grade of stainless being used? When I worked for the steamfitters union 7-8yrs ago, stainless is standard in all food and medical process pipe, as well as in industrial applications in which ethanol and methanol (both liquid and vapor) were used. Vin- I got a quote from a local shop that does ceramic coatings. They quoted me on the headers and 3x 2ft pieces of 2.5" tube Quote:
08-22-2015, 11:18 PM | #14 |
Vehicles cannot be compared to any other environment. Nothing else allows such drastic changes in temperature so quickly.Cars are their own environment. I can tell you aluminized pipe used to last 8-10 years and now it lasts 3-5 years. Stainless used to last indefinitely and now it is rotting out.
08-24-2015, 08:14 AM | #15 | |
08-24-2015, 12:36 PM | #16 |
meowMEOWmeowMEOW
That was from NorthStar machine&coating. They advertised doing the ceramic so I called there first.
Classic Coatings puts their prices up online, and they wanted $300 for a set
