Module eater
My truck is on the 5th module this year. Since the first of the year, I've rewired it, changed HEI, and still goes thru modules. Anybody have any ideas?
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
67-72 Addict!
Did you apply the silicone under it to dissipate the heat?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
is it getting a full 12 volts?if it's run on the original wire to the distrib it'll only get 7volts or so
Yes, I put the grease on each one, although it's getting enough buildup it may not need much any more.
Yes, it has a key on full 12 volts. I wonder if I need an additional engine ground?
67-72 Addict!
What is the gauge wire for the HEI?
Make sure your motor is grounded to the frame-frame to body. Is your battery grounded to motor?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
70c10, I'll check tonight.
Jhow66, I said to my wife at lunch that I would add a ground strap from the motor to the frame and see if that helps, yes, battery is grounded to the motor.
....are you buying ..Wells...modules?...i've never had good luck with Wells ignition parts..i always try to go ..Standard.. or better yet ...Borg Warner.... just a thought.....
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
its all about the +6 inches
I have to agree with Ken, what brand parts are you installing in there?
Adding a ground strap can't hurt, but since you have the battery grounded to the engine,a nd the dist. shaft is metal, you don't have a ground problem. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Sometimes on HEIs, a marginal coil will eat modules. I learned the hard way. I put in three AC Delco modules in my 83 in 6 months or so. Finally, it died again, so I got another module, but that wasn't it. It turned out ot be the coil. An old mechanic told me after all was said and done, that some coils get too much resistance in them and it knocks the module out.
I've had 2 different coils, I've used different brands of modules, last two from a jobber who supplies my friend's garage. They have a lifetime warranty, but I don't need any more practice. I bought an AC Delco one yesterday.
