08-20-2015, 08:02 PM | #1 |
Need e brake help
I need help. I rebuilt my new rearend from a 71 c10 it's a 12 bolt. I have a 63 can and frame it is going to attach to. However the rear end does not have any e brake cables etc. what would be my best course of action to get some. Are they the same do I look for 63 e brakes or 71??? Thank you so much you guys have been such a help this far.
08-20-2015, 09:33 PM | #2 | |
Re: Need e brake help
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
08-20-2015, 10:26 PM | #3 |
I do have a 63 Chevy with rear control swing arms. I do not however have a transmission crossmember at this time. I was just going to order a tubular one. Am I correct in assuming your saying if I upgrade to a 66-72 parking brake setup I do not need the crossmember linkage though
08-20-2015, 10:41 PM | #4 | |
I am NOT referring to the transmission crossmember under the bell housing. Here's a few pictures of my 1965 ebrake crossmember and frame. It's covered in grease and dirt under the drive shaft. I cleaned it up and the put it back in place when I was mocking up my conversion to the 1966 ebrake cable system.
08-20-2015, 10:47 PM | #5 |
Thank you I got it appreciate the help and experience
08-21-2015, 10:56 PM | #6 |
Hi revjames.
I'm not sure if you're aware that the Panhard Bar mount location on the '71 rear axle housing is different than the original '63. I had to deal with the same issue on my '63.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
