08-22-2015, 11:50 PM | #1 |
1996 454 tbi in 87 GMC. Easy swap??
Thanks to this thread I had to buy another truck because I fell in love with his truck and being a stepside. You just dont see step sides around here anymore. http://www.gm***************/forum/sh...ght=circuitguy
To make a long story short, I ended up with a long bed fleetside. 87 GMC sierra TBI. Im going to shorten the frame for a shortbed and am in on the hunt for a stepside bed. I have a forum member here helping me out on a bed. The truck has a tired but good 350 TBI with 700R4. Everything I got planned for the truck will take some time to plan. My question is, How hard would it be to swap in a 96 454 TBI into my 87. I have the complete donor truck. 96 suburban 2500. Runs excellent. I know they get real bad gas mileage, but in a lighter truck with the tbi and true dual exhaust everything else stock, should make for a fun truck to drive. Anyone done this swap?? |
08-26-2015, 02:57 AM | #2 |
Re: 1996 454 tbi in 87 GMC. Easy swap??
I can't personally say how difficult it would be, but I see the transfer case being an issue. Later Chevy's used independent front suspension and switched to driver side drop on the transfer case. Those 87's are passenger side drop. Also, I saw somewhere that 3/4 ton trucks used more splines on the transfer case than the 1/2 ton.
The wiring should be relatively straight forward. You are going to need most of the suburbans wiring. Never dealt with the big block stuff, so I don't know how the engine will sit in there. I'm guessing at a minimum you will need a new engine cross member and possibly a transmission cross member. Keep us posted on this! I have an 89 with a motor that will need rebuilding soon. Debating on whether to swap or rebuild.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
08-26-2015, 01:19 PM | #3 | |
08-26-2015, 12:30 PM | #4 |
1996 454 is not tbi. It's a vortec engine with mulitport injection. So if it is tbi, its 95 and older. The wiring isn't terribly bad, and just have the ecu tuned by a company to delete all the extra crap not needed. If it is a TBI, you need the ecu flashed. Vortec can be tuned with a program. I have my 97 tuned with out smog and all the extra crap that gm puts in their computers
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
08-26-2015, 01:26 PM | #5 | |
08-26-2015, 01:25 PM | #6 |
As for the physical swap part of it, get a set of big block towers and its a bolt in deal. The blocks didn't change as they got newer. If the 454 has a 400 behind it stock, its definitely an older tbi engine.
Posted via Mobile Device |
08-26-2015, 01:27 PM | #7 |
If your ultimate plan is ls, then save your money and keep your SBC..
08-28-2015, 06:33 PM | #8 |
I second that. No sense wasting time and money if your current setup works and will hold out until you get what you really want.
08-29-2015, 04:38 AM | #9 |
Yeah if your truck runs and drives now i would wait and go ls.
