Alternator Wiring Guru Help Needed.
Ok, my alternator went out yesterday on my 1970 C10. I ordered a new high 150 amp alternator from powermaster. I can't seem to find an answer on the website or here so.......it's going to be a 3 wire hook up with the sensing wire.
I ordered the alternator to battery larger 6 gauge cable at the same time. Do I hook this wire to the current battery junction box on the firewall that the old system used with the fusible linkage? Or go straight to the battery? Do I need to upgrade the fusible link? If I go straight to the battery, what would I use as overprotection so I don't blow up the battery or some crazy stuff? Anything else I'm missing? What about ground cable systems? Anybody have some diagram? Don't wanna fry the truck down. Thanks.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Re: Alternator Wiring Guru Help Needed.
http://www.madelectrical.com/electrical-tech.shtml here is a link that should help, I used their diagram for my truck and it works great.
#3 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
![]() Join Date: Sep 2013
VETTEVET IS THE MAN!!!!!!!!!!!!!!!!!!!!!!!!!!! Come and see me!!!!!!!!!!!!!!!!!!!!!!!!
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
I have a 7 gauge cluster but no amp meter. I have an aftermarket volt meter.
Where did you get your junction block from? Yes. If you have a drawing with the ground connections that will help also. Thanks
![]() Join Date: Dec 2012
I purchased and installed a power master myself, and their email support was awesome if that helps too.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Good info to know about their customer support.
150 amp? Holey smokes thats a lotta amps! I never needed more than 90 (ish)
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#9 | |
So the 100 amp alternator barely kept up, I figured I'd go the next one higher. The techs at powermaster said at an idle with all that I needed around 80 amp. A 100 amp alternator only put out about 70 at idle. I drive in heavy traffic at a slow pace sometimes. They recommended the 140-150 alternator.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
