C10 frame stiffening channel iron?
Does anyone company sell custom bent channel iron that fits inside the frame to stiffen it when shortening a c10 frame. I saw a write up on a c10 that i think hot rod magazine did and they used the channel for extra strength. They said the name of the company that sold them but i cant find the article. Thanks
Posted via Mobile Device |
#2 | |
Re: C10 frame stiffening channel iron?
I use 1/4" plate inside and out with 8- 7/16" grade 8 bolts on each side over the grafted/welded frame rail. Bit of an overkill, but never have to worry about it failing either. ![]()
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Early Classic Enterprises sells them.
Forgot about those guys! Frame stiffeners. $35.00.
Thanks guys. I ll check them out
I saw these in brothers or lmc catalog. Cant remember which
Be careful with those. You need to seal them so water and junk can't get betwixt them and the frame to start rusting.
Will weld thru primer hold up if i get the frame powdercoated after. Thanks
