Clutch / Brake Pedal hardware?
I removed and disassembled my brake & clutch pedal stuff a while back and I'm ordering new plastic bushing but I discovered this in the zip lock baggy?
Anyone know what it is called, where it goes and where to get a new one? thanks!
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Clutch / Brake Pedal hardware?
Pressure washer. Goes on shaft before it goes into bushings. Theres a solid washer on the outside behind the cotter pin. Looks ok, it's there to keep tension on pedal so it does'nt rattle.
Behind cotter pin??
Moderator
![]() ![]() Join Date: Aug 2011
Where to get a new one. . . Subscribing.
Moderator
Mine has this set up, no cotter pin:
http://67-72chevytrucks.com/vboard/s...d.php?t=587057
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
![]() Join Date: Jun 2015
Where did you order bushings from? Thanks.
