09-02-2015, 08:15 AM | #1 |
Stuck lug nuts
Anyone know a good way to bust free stuck lug nuts? I tried everything, from the stock wrench to a socket wrench with a4ft pipe on the end, still nothing. any tips? I also tried some wd-40 and pb blaster, still nothing.
Grandpa's '87 Sierra R1500. |
09-02-2015, 08:28 AM | #2 |
Re: Stuck lug nuts
I use a 4 way lug wrench. My problem is that tire shops and auto repair shops use air guns to reinstall the lug nuts and over torque them. I have sheared off wheel studs trying to remove a lug nut, so be careful. If you do shear one off, installing new studs is not expensive but is a pain.
09-02-2015, 09:03 AM | #3 |
Re: Stuck lug nuts
I've had the tire shops cross thread the lug nuts. Only way I got it off was an air chisel. Depending on the rim (and if damage is a concern) you may try some heat on the lug nut.
Also if you have access try an air gun. Anymore I request the shops to not use an air gun. I'd rather no be on the side of the highway and stuck because of something like that.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
09-02-2015, 10:52 AM | #4 |
Re: Stuck lug nuts
I soaked them for a bit and used a impact forward and reverse and it seems to do the trick.
09-02-2015, 11:24 AM | #5 |
Re: Stuck lug nuts
If the truck is drivable, then I would drive it for a while then try as soon as u get back. Also I would spray it with wd40 and let it sit for a while. Let that oil penetrate.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
09-02-2015, 07:58 PM | #6 |
Re: Stuck lug nuts
WD40 is NOT a penetrating oil. There are much better alternatives and work far better.
09-02-2015, 12:13 PM | #7 |
Re: Stuck lug nuts
Be careful using too much heat on a rim/tire full of air, they can explode. let the air out.
Paul |
09-02-2015, 01:16 PM | #8 |
Re: Stuck lug nuts
Try a nut splitter
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
09-02-2015, 03:26 PM | #9 |
Re: Stuck lug nuts
I like the nut splitter idea if all else fails. You can pick up a lot of factory lug nuts at the automotive recycling center for a few dollars.
09-02-2015, 04:47 PM | #10 |
Re: Stuck lug nuts
Never heard of a nut splitter...Is it the cousin to the ball buster..LOL
09-02-2015, 05:58 PM | #11 | |
Re: Stuck lug nuts
i have always had good luck with my 4ft braker bar. but thats not always the best. heat is good even a small propane one can work well.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
09-02-2015, 07:12 PM | #12 |
Re: Stuck lug nuts
The best penetrant (by actual testing on homemachinist forum) is a 50/50 mix of acetone and ATF. You can get acetone at the drug store. They sell it in pint plastic bottle as cheap nail polish remover. Drip it on the lug nuts and let it work overnight.
Do not have any ignition source anywhere near acetone, ever.
Rich Weyand 1978 K10 RCSB DD. |
09-02-2015, 07:31 PM | #13 |
driving is in my blood
Re: Stuck lug nuts
The solution is muscle and new studs after you twist the old ones in half where ever the nut is stuck at.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-05-2015, 08:06 AM | #14 |
Re: Stuck lug nuts
Try tightening them first - use a 4-way and that four foot cheater you mentioned. Then, even if they don't appear to move, quickly try backing them off - in the normal CCW direction.
09-08-2015, 09:38 AM | #15 |
78K & 79C Jimmys
Re: Stuck lug nuts
I try that too,works sometimes,my warped 1/2 inch breaker,fits in my floor jack handle...
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
