Rear end bad
Anyone know if a 81 Camaro rear end will fit in my 68 c10
Posted via Mobile Device |
![]() Join Date: Sep 2007
Re: Rear end bad
are you switching to 5 on 4.75 lug pattern?
1967custom |
Re: Rear end bad
78 truck bolt pattern is 5 on 5" pattern, car pattern (as previously mentioned) is 5 on 4.75". Wheels will not work. Probably easier to dig up another $150 rearend for the 73-87 truck.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#5 | |
#6 | ||
"I ain't nobody, dork."
Re: Rear end bad
You can make any rear end fit in these trucks.
If the "3rd member" is out of a 10-bolt... then no. Gary
Re: Rear end bad
If you have a Camaro 12 bolt posi it's worth more to the Camaro guy. You could sell it and buy a new posi/gear/bearings for your truck
Re: Rear end bad
Check on craigslist for chevy truck parts and look for a guy with more than one ad because that is usually the guy with the small chevy truck parts yard.
You shouldn't have any trouble finding a 71-72 5-lug rear axle, and even less trouble finding a 67-70 rear axle. |
Re: Rear end bad
It sounds like you're looking for a bolt in, in that respect; no, nothing except for a rear end from a 67-72 will fit if it's coil sprung. Even then, coil and leaf rear ends are different and won't just bolt in the opposite vehicle without slight mods.
The rear ends are also different widths between years. That isn't much of a concern unless you're running large tires or an odd backspacing. |
