Old 09-08-2015, 01:23 PM   #1
bs46488
Help with sloppy column shifter...
Hello,
I'm resurrecting a project truck from the PO.
Last month I got the truck back into running condition after many years with a BBC and a TH400 trans.
I hooked the trans up to the factory column shifter and it is really sloppy.
I searched and read a few threads and checked all the areas they were suggesting (bushings @ trans, bushing @ end of column, loose/adjust linkage, worn indents on column end) and everything is rock solid there.
Here is where I found all the movement in the shifter. I can wiggle the sifter back and forth and watch that section (with the red arrow) move on the column. It does not move one little bit on the other end of the column or at the trans connection.
(For those of you wondering, yes my seat is an upside down milk create)
bs46488 is offline   Reply With Quote
Old 09-08-2015, 01:53 PM   #2
tdangle
tdangle's Avatar
Re: Help with sloppy column shifter...
Mine was quite sloppy too. Had a bunch of play forward and back causing the pointer to hit the lens frame. I ended up fashioning a shim spacer out of some pvc pipe and was better. Never really figured out why it had so much play. Would love to just put a new tilt column in but big bucks $$$. I'm subscribing to this thread, maybe we can both get some answers.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-08-2015, 04:37 PM   #3
raggedjim
raggedjim's Avatar
That collar fits over a key on the shift tube and the shift lever inserts into a hole in that key. I have my column apart and will take pics tonight.
tdangle, you may have been missing this part
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 09-08-2015, 07:09 PM   #4
tdangle
tdangle's Avatar
Strange a piece would be missing, but it makes sense. I just cant imagine that my dad would have ever taken apart the steering column and he was the original owner.
Wish I could ask him.
Terry
Old 09-08-2015, 08:43 PM   #5
raggedjim
raggedjim's Avatar
I know what you mean, my dad died a couple years ago.
Now that I think about it you may want to check the bottom end of the column. There should be a bottom bearing, spring, then a washer that tends to force the shaft downward. Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 09-08-2015, 08:39 PM   #6
raggedjim
raggedjim's Avatar
Key on shift tube and collar on shift tube. The collar fits pretty tight around the key, it shouldn't have much play. The end of the shift lever fits in the hole in the key. Hope these help. Rg
Roger
'70 GMC Jimmy 2wd
