![]() Join Date: Nov 2013
ls swap throttle linkage
im at this point, has someone made a bracket that would save me some time? if not just post some ideas thanks!
![]() Join Date: Aug 2013
Re: ls swap throttle linkage
i am using the stock cable driven throttle from a 2001 silverado 5.3
Throttle linkage? LS swap is drive-by-wire homeslice.... (of course if your using a cable operated ls1 throttle body... i cant help ya)
2004 5.3L here ![]() ![]()
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
there are A LOT of cable throttle body ls engines...
and a few others
Moved this to the LSX area of the forum for ya
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Need more details, such as year of truck, intake manifold you are using, throttle body, etc.
For my swap I used the stock Silverado throttle cable and bracket. |
Old member
Not 100% sure but mine is a Lokar I think. Used factory bracket for it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The breather hose from the throttle body to the Passenger valve cover is missing, you should put one on there.
its the stock truck manifold, its going in a 63 c10 the cable is already mounted just like in andy4639 picture. basically i just need to hook it up so it works with the gas pedal
#12 | |
The Older Generation
Not to sound like an a$$ but if you are asked for pictures and you don't provide any you may not get much help. I just did my '67 Chevy with stock pedal and may be able to provide some assistance but I don't have a clue what your stock assembly looks like on the engine side of the firewall..... LockDoc
