Old 09-08-2015, 11:09 PM   #1
Chevys10dr
Chevys10dr's Avatar
Keyed 12v source.
Not the greatest at wiring, need help.
running an MSD box and Atomic EFI, I need to have a 12v source for both that supplies 12v in "on" and "start".
where would i start to find this?
Chevys10dr is offline   Reply With Quote
Old 09-08-2015, 11:50 PM   #2
toolboxchev
Re: Keyed 12v source.
Off the fuse panel under the dash. Just check which ones are keyed on with a multimeter or DVOM.
Pretty simple
toolboxchev is offline   Reply With Quote
Old 09-08-2015, 11:58 PM   #3
Chevys10dr
Chevys10dr's Avatar
Every open spot in the fuse box it shuts off the EFI when cranking the engine over. So i think they only supply in the "on" position.
Old 09-09-2015, 12:05 AM   #4
boynton
boynton's Avatar
Very possible. Try the back of the switch. I think the key on gives you power the whole time.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 09-09-2015, 12:21 AM   #5
Chevys10dr
Chevys10dr's Avatar
I will check the pink wire, hope it has power on both start and on. If no I will have to run a wire off the battery to a toggle switch.
Old 09-08-2015, 11:53 PM   #6
boynton
boynton's Avatar
Back of the switch. Purple will be your starter and pink should be you key on. Easiest way to double check it a cheap test light. There are also key on spots in the fuse box. You can also pick up a low voltage starter wire from your starter. I would not do this because you could cause your starter to burn up due to a lack of power since you are picking it up so close to the starter.
1970 SWB Step-Side
