Old 09-09-2015, 10:29 AM   #1
In The Ten Ring
Getting rid of and replacing this old caulk?
How do I remove this stuff from the heater core box and the firewall?
What do I replace it with?
In The Ten Ring is offline   Reply With Quote
Old 09-09-2015, 10:35 AM   #2
MY67GMC
Re: Getting rid of and replacing this old caulk?
Is that just dum-dum (3M strip caulk) or something else. If dum-dum, manual removal with a putty knife/scraper should do it.
MY67GMC is offline   Reply With Quote
Old 09-09-2015, 10:39 AM   #3
cooperhw
cooperhw's Avatar
Gas and a match. About a gallon should do. I kid.
Yeah, a scraper will get the bulk off and wire brush the rest. I used to stuff comes in a roll the AC guys call "Monkey Poop".
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 09-09-2015, 10:59 AM   #4
FirstOwner69
FirstOwner69's Avatar
As noted above. Scrape it off. I would then use mineral spirits to attempt to remove the residue. Most vendors sell "heater gasket" or "heater seal" kits.
FirstOwner69 is offline   Reply With Quote
Old 09-09-2015, 03:19 PM   #5
Big Kev-O
Big Kev-O's Avatar
Replace it with Butyl tape. It seals great and conforms under pressure to make a nice tight weatherproof seal that will last. Sometimes you can find it at the local hardware store or HVAC supply house.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 09-09-2015, 04:44 PM   #6
In The Ten Ring
Should I worry about the surface rust on the metal in the middle section?
Old 09-09-2015, 07:04 PM   #7
In The Ten Ring
Good to hear! I've been using that combination all summer on truck parts!
Old 09-09-2015, 10:32 PM   #8
leftybass209
leftybass209's Avatar
The benefit to removing it, is the flapper/diverter is under there. It is a metal plate wrapped with foam and stapled together. The foam can be deteriorated or shrunk, thereby not effectively diverting any air. I took mine apart and it didn't take very long to fix. I purchased a new heater seal kit and it made the job cake.
The seal kits come with a kneading type rope seal which is what you were asking how to remove. It can be purchased at any auto parts store, or better yet, the butyl tape would seal better.
leftybass209 is offline   Reply With Quote
Old 09-09-2015, 11:27 PM   #9
englands 71
englands 71's Avatar
I have a rubber wheel eraser that I put on my drill and use for stripes , double sided tape , glue etc.
on my box I used a good quality seam sealer. 3m
englands 71 is offline   Reply With Quote
Old 09-11-2015, 03:17 PM   #10
In The Ten Ring
That does it! I am going to take it apart as soon as I get my pants out of the dryer.
Old 09-11-2015, 03:55 PM   #11
ERASER5
ERASER5's Avatar
I'm afraid to ask....
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-11-2015, 06:32 PM   #12
In The Ten Ring
Don't then! LOL
I have the heater box apart, using my drill on the rivets. I used a scraper to remove the caulk, followed up by a washing brush and dish washing detergent. There seemed to be a lot of "road grime" in there. There was also a great deal of pine needles, in a place I don't think I could have gotten to without this level of disassembly.
I am afraid to drill out the rivet holding the flap control as I am not sure if I can get my rivet tool back in there to re-rivet it. Now the metal in the center section (with the opening in the center) I now have soaking in Evaporust so at least that will be de-rusted. The rubber around my flapper seems to be soft so I won't replace it.
How do you get the round rubber gasket out of the right side (of the pic)? This is opposite the fan. Is it just glued in there?
Old 09-12-2015, 08:00 AM   #13
You only have one pair?
Old 09-12-2015, 01:42 PM   #14
In The Ten Ring
Yep. Only 1 pair for working in. Odd set up for sure!
