Old 09-09-2015, 11:07 PM   #1
englands 71
englands 71's Avatar
Another Temp Gauge Question
My temp hand is pegged on H.
I ran a ground wire from the bottom nut on the gauge to the windshield wiper nut (just to see if it moved) it smoked the printed circuit board. I can see where it burned the copper wire on the circuit board. I'm going to buy a new board tomorrow . Is there anything else I should buy and/or do while I have the dash cluster out . I don't want to buy one and trash it again . Why did it burn it when I touched it to the wiper nut ?
englands 71 is offline   Reply With Quote
Old 09-10-2015, 10:10 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Another Temp Gauge Question
Originally Posted by englands 71 View Post
my temp hand is pegged on h.
your sending unit is bad or the wire from it is grounded, or the gauge terminal is grounded. Disconnect the sending unit on the engine and see if the gauge moves. If it doesn't the wire may be grounded. Check the diagram below.
i ran a ground wire from the bottom nut on the gauge to the windshield wiper nut (just to see if it moved) it smoked the printed circuit board. I can see where it burned the copper wire on the circuit board. I'm going to buy a new board tomorrow . Is there anything else i should buy and/or do while i have the dash cluster out . I don't want to buy one and trash it again . Why did it burn it when i touched it to the wiper nut ?
you shorted the copper strip to the grounded nut on the wiper motor. Which post on the gauge in the diagram did you connect to the wiper motor nut?
the two horizontal post on the gauge are supposed to be insulated from the cluster body. If the right side (12 volts hot) is shorted it will burn up the copper strip. If the sending wire post on the left side is shorted to the cluster body it will cause the gauge to read hot all the time (key on ).
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-10-2015, 12:56 PM   #3
englands 71
Originally Posted by VetteVet View Post
I touched a wire the the bottom nut and touched it to the nut on the dash that screws onto the wiper knob with the key on.
Old 09-10-2015, 04:46 PM   #4
englands 71
The silver post
Old 09-10-2015, 05:47 PM   #5
Davidf
The copper traces on the "circuit boards" can be easily repaired with a bit of soldering skill. Carefully peel/scrape back plastic covering broken ends of copper traces. Tin both ends of the broken trace. Place a piece of copper wire over the tinned ends and touch with soldering iron...done.
Davidf is offline   Reply With Quote
Old 09-11-2015, 12:13 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Grounding a ground shouldn't have burnt the copper strip. Check the resistor and make sure there is resistance between the two posts.
What about the other tests?
VetteVet
Old 09-13-2015, 08:53 PM   #7
englands 71
pulled out the instrument cluster and the printed circuit was damaged where the main harness hook in. Put in a new printed circuit and fix my temp gauge problem.
Thanks for you help ! Problem solved.
