Aftermarket sway bars
Opinions on buying aftermarket front and rear sway bars? I don't have either on my c10. Brothers is having a sale until the end of the month. Sway bar, mounts and links for 100 bucks each. I was planning on buying the Belltech rear setup but I could buy both from Brothers for that price.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
Cruzzzn' Vet
Re: Aftermarket sway bars
I would go for it
I was hoping someone would confirm if they are decent quality parts.
The Bell bars are nice pieces. I have both but front and rear bars. You'd be happy with just the front if you have none now.
I know the pieces fit
I wouldn't put on a rear bar without trying it with front only for a while. I remember gchemist commenting on his setup once and said something to the effect that it was pretty lively with front and rear bars.
Lively how?
As I reassemble my truck, I will be installing a CCP front and a 1 ton I picked up from 1774btcrew for the rear.
My biggest concern is the quality of the one sold by Brothers.
http://www.brotherstrucks.com/prodin...number=HELF576
Quality is probably ok. That bar is pretty small though. The big factory bar is 1.25". It will still work circles around what you have now. If you can get it for $100 I'd do it.....
Adding a factory sway bar to my 84 was the cheapest and best upgrade I have made to my truck. Made a world of difference in the handling and cruising,
Thanks for the opinions!
driving is in my blood
Just get a 1ton's 1 1/4" solid front bar from the junkyard. As good as any aftermarket for street driving.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Honestly, because I don't have the time to go to the junkyard and pull one. Then by the time I do and clean it up and replace the bushings and links I'll probably be close to 100 bucks anyhow.
#15 |
![]() Join Date: Mar 2013
Does your truck have the factory sway bar brackets riveted to the frame? How much is your truck lowered? I was in the same situation as you and installed this:
http://www.summitracing.com/parts/bel-5404 My Jimmy didn't have a factory sway bar so I drilled the frame and bolted the brackets supplied with what I listed above right to the frame. Worked great and I'm very pleased with how it handles. You can just barely see it in this pic. |
#16 | |
#17 |
After reading this thread, went to Brothers site. I think for $100 you can't go wrong. I have a factory bar on the front of my truck but wanted to try a rear bar and for that much I have to try one. Going to order tonight.
#18 |
So you don't feel you needed these?
http://www.belltech.com/products/bel...r-adapter.html Also will an LS 5.3 interfere later down the road?
#19 | |
Sway bar should have no effect on LS fitting or not. |
#20 |
if you lowered more the 3" i would check to see if it comes with lowered brackets. my truck is dropped 4.5" front. i bought cpp sway bar off ebay an it came with stock an lowered brackets. tried the stock ones first. an it was a no go. had to use the lowered ones
#21 |
I decided to get this kit from BellTech. From my supplier it is 264.93 plus some shipping for both bars.
#22 |
I used the factory brackets on the 1 1/4 bar I installed and my truck was 5" down in front as well.
#23 |
Any pics?
#24 |
http://www.belltech.com/products/bel...ets-14036.html
Sorry, here's the link to what I was referring to. I ordered this kit just at a better deal.
#25 |
I made a template to drill the frame holes. I can post dimensions I used for installing the Belltech bar on my 82
