LS Air Intake Pics?
![]() Join Date: May 2010
Re: LS Air Intake Pics?
First beautiful truck!
You might have better luck posting this question in the LS swap area. I'm trying to figure out how to run my cold air intake right now. I will post up some pictures when I get it figured out.
It only has original paint once |
meowMEOWmeowMEOW
You def will have better luck in the LS section. FWIW, here's a video I did about building my cold air box, and it shows the intake we used and the changes we made.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Hope this helps
#5 | |
Here's one I seen at a car show Saturday. You'd have to relocate the battery.
You can find me on Instagram @neveno_cten |
I ran mine down to where battery used to be, moved battery to drivers side. Used 4 inch semi exhaust pipe 90's cut and trimmed, welded to fit with K&N cone filter. Used straight rubber sleeve and 2 heavey clamps to connect to TB on 2005 5.3 in 68 Chevy C20. Look at my build pics.
I didn't. Just put a cone filter on the throttle body. I'm running speed density, so there's no MAF.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Old member
I used it on my 305 TPI motor and now on the 6.0 Ls motor.
Caddy air box modified by me. 4" ninty with 2 couplings from Lowes mounted on the radiator support where the old voltage regulator went. Some day I'll modify the top so I can run a solid tube over to the intake. ![]() ![]() ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Rex |
here's mine.. spectre 4", $150 from summit. half the price of a K&N.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
3.75" x 3.5" Reducing 90 with Vibrant 45 tubing part #2890 and a 9" Spectre
