09-15-2015, 11:22 PM | #1 |
Front disc brake upgrade
I bought these brackets to put bigger brakes on my k5, then i changed directions to put stupid big brakes. These bolt up hummer h3 fixed 4 piston calipers and give you incredible stoping power. These sell for 60.00 + shipping I've never opened the box. Here's the blurb from the guys making them.
These brackets fit Dana 44 (and Corp 10-bolts) with GM/Jeep 6-lug hubs. The standard Dana rotor position must be converted so the rotors slip-on over the hubs, like a normal disc brake set-up. This requires new wheel studs, and some minor machining to the hubs so the Hummer rotors can slip-on over them. I can do this machining to your hubs, or if you prefer...you can do this locally if you know a machine shop with a lathe. Other parts you will need are: Hummer H3 calipers Hummer H3 brake pads metric mounting bolts Hummer H3 rotors How about 60.00 shipped ? |
11-30-2015, 09:28 PM | #2 |
Re: Front disc brake upgrade
Anybody?
06-14-2016, 06:14 PM | #3 |
Long shot being over a year old but still have these brakets for the h3 calipers and what not??
94 Silverado 1500 ext. Cab short bed 350 nv4500 (factory) 78 K20 350 (soon to be 400sbc if I can find one) sm465 205 dana44 14bff 6in lift on 37" militarys |
06-14-2016, 10:30 PM | #4 |
I just gave them to a buddy
06-15-2016, 12:38 AM | #5 |
2 questions
1. Where did you originally get them? 2. You said you decided not to use those to use stupidly big brakes? Got info on that setup?
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
06-15-2016, 07:18 AM | #6 |
Here's a post all about these brakes, http://ck5.com/forums/threads/pure-chevy-sex.316597/ I actually am working on swapping a trailblazer ss chassis under my k5 and it will have 14 inch stoptechs for stupid big brakes
06-16-2016, 10:52 AM | #7 |
Dang I was hopeing you still had but knew being over a year old alim chances... the guy is wanting over $100 for just the brakets... I think ill make my own...
06-16-2016, 11:56 AM | #8 |
I think I gave 100.00 plus shipping
