09-16-2015, 07:03 PM | #1 |
'62 305 v6 5.0l
Hey guys,
this might be a dumb question but i have an immense amount of grease and oil buildup on my engine. ive scoured the internet high and low and cant find where my oil filter canister is located in this engine. im trying to give her an oil change and have the new canister. i thought it would be on the drivers side just next to the distributor but im not seeing it. any help or pics would be greatly appreciated! Also, my truck has an alternator from an 80's chevy. im looking to go back to an original generator for it instead. any pros/cons to doing this?
1962 GMC 2500 3/4 ton longbed stepside (currently w/flatbed), 4 on the floor, 305-V6-5.0L |
09-16-2015, 08:04 PM | #2 |
Re: '62 305 v6 5.0l
the oil filter canister is on the driver side bottom rear by the bell housing and it is big you can't miss it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
09-16-2015, 08:36 PM | #3 |
Re: '62 305 v6 5.0l
STAY with the alternator FAR superior to any generator (There are reasons they dont use them anymore)
09-16-2015, 09:20 PM | #4 |
Re: '62 305 v6 5.0l
Yep, stay with the alternator. Oil filter is on the driver's side near the bottom by the bell housing...go under the truck and you'll see it in an instance. lol Unless its gone somehow.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-16-2015, 10:59 PM | #5 |
Re: '62 305 v6 5.0l
great, thanks! ill try again tomorrow
09-16-2015, 11:22 PM | #6 |
Re: '62 305 v6 5.0l
Alternator with generator look from Speedway Motors.
http://www.speedwaymotors.com/Early-...-Amp,5867.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-17-2015, 04:38 PM | #7 |
Re: '62 305 v6 5.0l
i dont know what the hell is wrong with me, if im blind or my truck is so coated in grease i cant find the oil filter canister. i got underneath the truck to try and find it but came out with nothing. does anyone have any pictures or videos on where the heck this thing is? i thought i found it behind one of the valve covers but that can type canister had a long spout coming out from it that went straight down. any idea what that is? uploaded a few pics of what im working with. the replacement given to me from oreilly auto seems to be about as big as the larger part of the starter.
09-17-2015, 05:01 PM | #8 |
Re: '62 305 v6 5.0l
The pipe in the picture is a crankcase breather or road draft tube,If I remember right some early v6s did not have oil filters,it should be next to oil pan near bellhouseing {dark area in above picture} or a big can remotely located somewhere??
09-17-2015, 05:04 PM | #9 |
Re: '62 305 v6 5.0l
so theres a possibility i just drain the oil pan and refill through the valve covers? no oil filter at all in the truck? that would sound about right since theres nothing the size of the starter around the oil pan or bellhousing
09-17-2015, 11:15 PM | #10 |
Re: '62 305 v6 5.0l
jteck take a pic (with flash) straight up just in front of that tube on the drivers side
09-18-2015, 10:33 PM | #11 |
10/30/19
Re: '62 305 v6 5.0l
The canister for the oil filter will have a long 5/8ths bolt that runs straight through the middle of the canister. I'm not sure but, in the first picture, it looks like there is some kind of adapter plate with a knob for a lack of better word. First picture, left hand side, towards the middle.
Edit:After looking at it again I think that's where the filter is supposed to go. I think you're missing the canister.
Fight the good fight, finish the race, keep the faith |
09-19-2015, 04:38 AM | #12 | |
Re: '62 305 v6 5.0l
09-19-2015, 08:37 AM | #13 |
Re: '62 305 v6 5.0l
09-19-2015, 01:42 PM | #14 |
Re: '62 305 v6 5.0l
Here is a canister oil filter housing location photo. Located on bottom left, this one is longer then the ones used in light duty trucks.
MusicMan70 1961 GMC Suburban |
09-19-2015, 02:02 PM | #15 |
Re: '62 305 v6 5.0l
i definitely dont have a canister there like this one. the truck once was a dump bed, and all the hydraulics and other stuff was cut out. ill go get a picture of the tubing with flash now as thats where i originally thought the oil filter would be
09-19-2015, 06:37 PM | #16 |
10/30/19
Re: '62 305 v6 5.0l
Definitely my error. I'll blame it on my phone.
09-19-2015, 07:24 PM | #17 |
Re: '62 305 v6 5.0l
You were right its a dana like this one on ebay http://www.ebay.com/itm/262033375665...%3AMEBIDX%3AIT
09-18-2015, 11:34 PM | #18 |
Re: '62 305 v6 5.0l
Mine is on the driver side of the engine by the oil pan. If I can figure out how to load a video, I'll post this one I just took.
Posted via Mobile Device |
09-20-2015, 02:57 PM | #19 |
Re: '62 305 v6 5.0l
i guess i have to add one in. ill probably aim for the canister type. anything i should be worried about or watch for now that i know i havent had an oil filter for i dont know how long?
09-20-2015, 03:31 PM | #20 |
Re: '62 305 v6 5.0l
hey if its running ok drive the ---- out of it,change the oil a little more often,looks like maybe the frame was notched for the PTO might wanta look see if they put a brace or something in there,look at 1st picture i cant tell ;if the frame was cut it should be beefed up. on second look maybe thats the floor ?
09-20-2015, 03:44 PM | #21 |
Re: '62 305 v6 5.0l
Floor
