09-19-2015, 07:09 PM | #1 |
Where to get vacume off 250 i-6
I,AM WANTING to put power brakes on my 70 c-10, it has a 250 I-6 engine and I don't know where the factory connected the vacume line to the booster. could somebody tell or better yet post some pictures of there setup ?
thanks bob
I BELIEVE IN JOHN 3:16 |
09-19-2015, 07:38 PM | #2 |
Re: Where to get vacume off 250 i-6
Should be a plugged port right below the carb on the intake plenum for that.
09-19-2015, 07:41 PM | #3 |
Yup. Soak it with PB Blaster or your favorite penetrant for a day beforehand. Get a 1/4" NPT barb for the hose to connect to.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-19-2015, 09:42 PM | #4 |
I think I know the one your referring to. on mine its in the manifold between carb base and valve cover side of intake correct ? thanks fellas. one last thing is the master cylinder cardone #10-1511 for manuel brakes the same m/c as power brakes ?
09-19-2015, 10:02 PM | #5 | |
You want the one on the outside below the carb. |
09-19-2015, 11:47 PM | #6 |
oh, I,ll look asap for it then,thanks
09-20-2015, 12:30 AM | #7 |
found it guys. bet this is gonna be a bugger to get out ! also looks like a 90 or 45 degree barb fitting will be needed. are the booster and m/c different for 71 & up trucks compared to 1970 drum brake trucks ?
09-20-2015, 10:09 AM | #8 | |
A little propane torch should work. Don't get lazy and think you can tee into the pcv line. The booster needs it's own vac source. If you need a factory looking fitting to hook your vac line to, look here. https://www.paragoncorvette.com/c-22...aspx?pagenum=1 |
09-20-2015, 02:37 PM | #9 |
Mine wasn't hard to get out. Sprayed PB on it for a few days and it threaded right out. Used a straight barb...a 90 might've worked too but I didn't feel it was necessary.
09-20-2015, 07:19 AM | #10 | |
Now, I need to get out the rust penetrant and soak that up. I have already soaked the front end with penetrant, which hopefully makes it easier to remove most hardware. Bill |
09-20-2015, 02:39 PM | #11 |
Also, if you want the correct air cleaner for power brakes this is what you're looking for.
09-20-2015, 04:32 PM | #12 |
wow, I,d like one of those air cleaners for sure . believe it or not ny 70 has a touch over 19 k miles on it. still has priginal spare tire and exhaust. know of anybody who has one of the air cleaner assys for sale ?
thanks bob
09-20-2015, 07:30 PM | #13 |
well I looked at my 70 and the plug for vac isn't even corroded plus I looked thru my 250 engines and found the original vac line fitting,lucky me I recon. but while looking at the engine in my truck there definatly isn't room for a brake booster with the air filter mounted on top of the carb so now I,ve got to hunt down a p/b air filter. my engine has a Rochester mono jet carb.
