09-20-2015, 04:14 PM | #1 |
Bent Frame?
What do you guys think? If you look at the left and right spring hanger you can see the right one is lower than the left one.
Do you think this is signs of a bent frame? |
09-20-2015, 06:25 PM | #2 |
Re: Bent Frame?
I can barely see anything with those "rays of sunshine" in your pic.
John 82 Chevy Silverado 350ci/TH350 |
09-20-2015, 06:30 PM | #3 |
Re: Bent Frame?
Yeah I apologize.. Here is something better. I took measurements to the bottom holes on the frame horns..
Right frame horn: Left frame horn: |
09-20-2015, 06:41 PM | #4 |
Re: Bent Frame?
Somethings bent. Look at pic 2 and 4 where the Fram horns come out under the bumper. Pic 2 has a bigger gap then pic 4
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
09-20-2015, 06:50 PM | #5 | |
Re: Bent Frame?
You can see in these two pictures there are different body mounts in place. If I was to make them the same the one on the left would skew the body up by the amount the frame is twisted. Right side: Left side: |
09-20-2015, 07:54 PM | #6 |
Re: Bent Frame?
It looks like the body bushings are bad notice how the core support bushing on driver side is crushed more than passenger side these trucks do tend to lean as well
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-20-2015, 08:00 PM | #7 |
Re: Bent Frame?
just read previous post it could also be the other cab mounts making cab lean to one side measure all the mounts
09-20-2015, 08:02 PM | #8 |
Re: Bent Frame?
Body bushings won't affect the frame horns. If the body bushings were awry the body would appear all twisted which its not.
09-20-2015, 09:00 PM | #9 |
Re: Bent Frame?
Not if body was bolted together before mounts went bad my 74 the doors lined up and so did the fenders until I pulled it apart then it settled and doors shut like crap and the front clip wouldn't bolt up right and it because the mounts had collapsed and when I unbolted it it allowed everything to move when I put the new body mounts in the problems went away I'm not saying your frame isn't bent but there is a chance it isn't
09-21-2015, 01:17 AM | #10 |
Binder Rep
Re: Bent Frame?
I agree that you can't go by the gap, as the body mounts could be the culprit. A slightly sagging spring on the opposite side would give you that illusion of a bent frame as well.
It's really hard to verify a frame's condition without a jig IMO. If you could find a perfectly level spot (again hard to do) and put the truck on jack stands on the frame, aft of the suspension, you could get some decent measurements that way. Do you happen o have access to a lift somewhere? First thing you need to do is get the suspension out the equation. |
09-21-2015, 08:12 AM | #11 |
Re: Bent Frame?
I am going to take some raw measurements from axle to frame and ground to fender openings and see what that is like.
Then I will find a lift and see if that changes anything. |
09-21-2015, 10:56 AM | #12 |
Re: Bent Frame?
They look like completely different types/style front core support bushings
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
09-21-2015, 11:43 AM | #13 |
Re: Bent Frame?
09-23-2015, 08:04 PM | #14 |
Re: Bent Frame?
Wow. BUT...these frames weren't that great from the factory. You have to remember, these trucks were built on a production line, in a time when fixtures were horrid, quality control was loose at best, and drugs and alcohol were rampant in factories and a more accepted fact of life. To expect a frame for one of these trucks to be spot-on level is foolish. An inch off doesn't surprise me. I repaired wrecked GM cars that had 2 shims on the right front core support, and 8 on the left to get the front sheetmetal to line up. GM made the bodies look good with shims and bushings. I have a fairly unmolested '85, and from what I've seen, quality control was severely lacking then-- nowhere near what it is today. The fellow I bought it from worked at the Flint plant; he told me I didn't want to know what they did to cabs to make the doors open and close, because they didn't weld them together right. My driver's door to me still does not close at all within an acceptable tolerance. You literally have to slam it to get it to close. Bottom line - that might just be a stock frame that's never been wrecked. If the truck has been jumped...well...there you go.
09-23-2015, 09:40 PM | #15 |
Re: Bent Frame?
I have found a warp in the frame just near the power steering box that confirms the frame WAS tweaked at some point.
The rest of the frame seems ok but I also had to remove the rear bump because they decided to weld 2" pipes from both sides of the frame to the bumper causing some twisting as well. I will be taking a few cutting wheels and the welder and fixing the horn so I can put the bumper back on straight. Then I will rip out the front cross member and fix that as that is all bent up as well and fix the sway bar mounts as those are all twisted up as well. |
09-26-2015, 06:15 PM | #16 |
Re: Bent Frame?
Well found MORE issues still It appears the right frame horn is pushed back or the left frame is pushed forward.
Straight on shot: Left bumper side: Right bumper side: |
09-26-2015, 11:16 PM | #17 |
Re: Bent Frame?
It could still be a sheet metal problem. There are a couple inches of room for adjustments in the core support, fenders, and cab alignment. I would not use the sheet metal as the true square for measuring the frame. It's more likely that the sheet metal is crooked and/or body mounts are shot. Without a jig it is very hard to figure out what part, if any, of the frame is out of alignment. You can make educated guesses by measuring triagulated known points on the frame but even then the rails are not mirror images so finding reference points that match on both sides is tricky.
09-26-2015, 11:59 PM | #18 | |
Re: Bent Frame?
09-27-2015, 12:20 AM | #19 |
Re: Bent Frame?
To check the "square" of the frame. Find 4 holes, two in the front and two in the back in the frame. Make sure they are mates. Same on drivers side and passenger side. Take some fishing line and sinkers. drop lines from those 4 holes. Making sure that the line leaves the holes at the same point side to side. Then measure Right front to left back, and left front to right back. That will tell you if the frame is square.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
09-27-2015, 12:30 AM | #20 | |
Re: Bent Frame?
Thank you very much! |
10-02-2015, 10:10 PM | #21 |
Re: Bent Frame?
Check for a bow down under the cab... if the bottom of the frame is not flat with the ground, its bent.
My personal opinion is its bent. As a beater truck, drive it. If you are going to do a ground up show truck thing, buy another frame to start with. |
10-02-2015, 10:54 PM | #22 |
Re: Bent Frame?
I was hoping it wasn't going to be beater truck. But I can't even get the front bumper to sit properly so... plans will be chaning.
10-03-2015, 02:21 PM | #23 |
Re: Bent Frame?
No chance for a front frame graft? I have a nice 1979 front frame for a C10 all the way back past the transmission. Sand blasted and epoxy primed, complete with cross member. If you are willing to drive south to get it, I would let you have it.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
10-03-2015, 03:13 PM | #24 |
I know the pieces fit
Re: Bent Frame?
I would at least price a repair at a frame shop. It might not be much dough to pull it out "good enough". Seems like it'd be an hour or less on the rack to get the one frame horn pulled back out.
10-03-2015, 03:18 PM | #25 |
Re: Bent Frame?
C's and K's have a bit different frame at the front. They can work and many have been converted. But I'm not sure he's up to that right now. If it is out of square (Diamond) it would have to hit the rack and get pulled. Price "shouldn't" be too bad pricewise. It seems that there are 2 intertwined issues on it. The twist and diamond. The twist MAY not be there and all the misalignment may be due to mounts. I would take a measurement of all the body mounts as it sits. This would give an idea of the situation of the body mounts and the twist on frame. Its always better to measure twice and buy once. One other thing. When you go to measure the square on frame. get it on as level ground as possible. Use a level or an angle app on your "smartphone" and remember the angles of the ground. then measure the levels on the frame side to side. And compare. I think you will be able to see whats going on with the framw.
