Old 09-25-2015, 08:50 PM   #1
Blue GMC
Blue GMC's Avatar
Had anyone used this?
Just bought the 3M paint defender system. The boxes say it sprays on a film layer that protects from rock chips exc in the areas of application. Also says that the clear film will be able to peel off after one year.
I was thinking about using this on the front of my 71 hood since it is a flat surface that everything loves to hit.
Blue GMC is offline   Reply With Quote
Old 09-25-2015, 09:09 PM   #2
harrisoncole4
harrisoncole4's Avatar
Re: Had anyone used this?
I have used the 3m clear wrap like material but not this. 3m is a very reputable company so it would be worth giving it a try. Do several coats of it so that its thick enough to be removed. Kinda like plasti dipping. That's just my $0.02
harrisoncole4 is offline   Reply With Quote
Old 09-25-2015, 09:56 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Had anyone used this?
I bought some the other week but haven't used it yet. For the same purpose as you.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-25-2015, 11:11 PM   #4
tsetsaf
Interested in your findings. I assume it is like plasti dip. Do a test surface first. I do have the peel and stick 3m on my rockers and wheel wells... it works very well. Was warned off by an oem installer suggesting it can actually peel the paint off when removed in the future.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 09-26-2015, 01:00 AM   #5
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Had anyone used this?
A couple of things turn me off on the film. The edges get dirt around them and you cant get it out. When you peel the film off you have the glue left on the vehicle.
Old 09-26-2015, 10:48 AM   #6
Blue GMC
Blue GMC's Avatar
The dirt on the edges is also the reason I went with this as well hopefully I will be able to get to it this weekend
