Old 09-26-2015, 06:25 AM   #1
ACII
Throttle body top mounted ?
Hy together..
i would like to get a more traditional look for my ls1 setup :-)
On the net i saw some setups which have the throttle mounted on the top of the engine...almost like a carburator.
Finally i want to install 2 throttles (or 3 smaller throttles) on the top.
I would use and adapt an intake like this one =
http://www.ebay.com/itm/262063143749...749%26_rdc%3D1
The plan is to close the original opening on the side and weld in 2 or 3 mounting plates for the throttle on the top of the intake manifold.
Furthermore i would like to use all the sensors, but i have no clue how to handle the mass air sensor .....even more if installed 2 or 3 throttles..
Any ideas ??
What do u think about this plan ??
Thanks a lot
Achim
ACII is offline   Reply With Quote
Old 09-26-2015, 03:45 PM   #2
BigDan3131
BigDan3131's Avatar
Re: Throttle body top mounted ?
Why go thru all that work if you want it to look like a traditional small block?
Have you seen these? https://www.holley.com/products/ls_p.../parts/300-121 Its for use with dual throttle bodies and will give you the traditional look.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-26-2015, 04:41 PM   #3
ACII
u r right.....after checking some websites i also found this intake from Holley.
So far looks as a pretty good solution...
Finally i want to achieve this kind if look
http://www.alsblowers.com/streetinduction.html
So i still have to check which throttle body to use either ITB (maybe twinbodies) or a 4500 holley TB ??
CU
Achim
Old 09-26-2015, 06:11 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
that kit from ALS is fake ITB's....which I just can't co-sign the idea of.
If you want real ITB's that use a drive-by-wire stock throttle system, the people to check out are Jenvey.
http://www.jenvey.co.uk/
They do some of the most insane intake/carb/injection products out there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-27-2015, 04:29 AM   #5
ACII
i know with a fake ITB it is not the way to go ....it was just an example i would like to go with the horns.. i love that look when they are not so straight.
I heard and read a lot of the jenveys but unfortunately they are way out of my budget..
My current favourit is to use the edelbrock intake with some ITBīs of V8 BMW.
Here in Germany a lot of V8 engines have ITB, partly u can get them for a reasonable price here...
Old 09-28-2015, 02:49 PM   #6
bs46488
I don't know if this is what you were looking for, but check out how he did his swap:
http://67-72chevytrucks.com/vboard/s...erent+approach
At post #5 you start to see what he's doing. Than scroll down to post #16 to see the finished look
bs46488 is offline   Reply With Quote
Old 09-29-2015, 05:32 AM   #7
ACII
GEnerally it is exactly what i am looking for , but i want to install horns to get that kind of classic look .....
So i cannot copy that idea of installing the MAF inside the air filter, but it is a very clever solution !!
Thanks for the link !!!
Old 09-29-2015, 01:18 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Achiim, if you have the ECM tuned for Speed Density, you can ditch the MAF all together and run whatever type of intake you want.
Old 09-29-2015, 01:58 PM   #9
nsulacountry
+1 Rev, you read my mind on this one. Personally I am planning to run a SD tune. The tech articles on BD Engines site convinced me it's better than MAF tune.
CT
nsulacountry is offline   Reply With Quote
Old 09-29-2015, 02:25 PM   #10
ACII
i guess i need to go without the MAF ...so far i just read a bit about SD Tuning..
i will get into the BD site asap...
So far i got some informations that the ECM goes automatically in the SD Modus without the MAF plug is installed...
is that right ??
Thx
Achim
Old 09-29-2015, 05:04 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yes, but its a little more complicated than that. The ECM uses VE and PE to fuel the engine, much like how a carb uses primary and secondary jetting.
The MAF is part of the engine control feedback loop and uses the measurement of Grams of air to provide a correction factor. The 02 sensors provide feedback on STFT & LTFT.
By unplugging the MAF, your setting that portion of feedback to "fail", and making the engine rely solely on its fuel and spark tables WITHOUT correction. This means that the engine doesn't "know" how much air is coming in, but can calculate how much "should" be coming in based on the speed (velocity) to calculate density (basically what the MAF measures). Essentially what this means is that the quality of the work being done on the VE, PE, and spark tables needs to be extremely good. It generally also means switching the operating system on the truck from a standard MAF-Tune, to an SD Custom-OS if your using HP Tuners.
Without getting into the whole debate about SD; it will in general make a little more power, and be even more beneficial if you start going into boost above what the stock MAF and MAP can measure. BUT its crucial that the street and WOT tuning are very well done (VE tables need to be corrected and smoothed, PE needs to be set properly, High and low octane tables both need to be fully repopulated). I would not suggest SD for people who are having simple mail-order tunes or flashes.
Old 10-02-2015, 12:49 PM   #12
ACII
hy
finally i will go with some individuals throttles from a BMW M3.
The throttles have a size of 52mm, so should be big enough for some future tunings :-)
Using the individual throttle bodies i have to go without a MAF. So i will have to tune it via HP Tuners respectivly do it with a expert. Its hard to find but we do have some LS experts also in Germany ;-)
For the intake manifold i am still fighting ...
Pls let me know which effect does have a high ram intake respectivly a low intake ???
pls consider that i still use the EFI setup.
Also i got an information that the position of the injectors have an effect on the performance....that means the bigger the difference between injector and intake valve the more rpm the engine can get..
Is that right ?
i am curious on ur response :-)
Thanks a lot
Achim
