09-12-2003, 03:38 PM | #1 |
Tranny snaps my neck from 1-2
should I be worried that my trannsmission shifts extremely hard from first to second, is this bad for the tranny?
84 Silverado, |
09-12-2003, 03:47 PM | #2 |
www.73-87chevytrucks.com
No, it isn't bad. My opinion it is good. Sounds like you have a shift kit installed in it. Get worried when it starts slipping.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-12-2003, 03:54 PM | #3 |
I didn't recieve the neckbrace that should of come w/ the shift kit..
84 Silverado, |
09-12-2003, 04:20 PM | #4 |
driving is in my blood
shift kits and hard shifts are a good thing.....
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-12-2003, 05:15 PM | #5 |
I'm back with 2nd truck!
Wait a second guys if he as a 7004 and the TV cable in not adjusted right couldn't this cause it to do this as well and ruin his tranny? But if you have a TH350 or a TH400 then you're fine Sounds like mine when I'm on it. That 2500 stall kick in (sometimes 3000 ) and I'm off.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
09-12-2003, 06:15 PM | #6 |
my 700R4 does that, but of coarse i PAID BIG $$$$ for that 1800.00 buck as a matter of fact
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
09-12-2003, 07:05 PM | #7 |
Professional Grade
My TH450 does that too, its beefed up to survive the beating my engine gives it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
09-12-2003, 10:34 PM | #8 |
I have the 700R4 and now I am concerned about theTV cable.
what is that? Guess, the cable from the throttle to the tranny..? How do I know if it is adjusted right.
84 Silverado, |
09-12-2003, 11:07 PM | #9 |
Don't foget vacuum leaks! My brother-in-law's '79 diesel used to shift hard from 1-2, hard enough to move your neck, because it didn't shift early enough. It would wait until near full rpm to shift. Hard on you and your transmission. Anytime vacuum is involved check the lines for leaks.
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive! |
09-13-2003, 01:35 AM | #10 |
It doesn't matter what RPM im at, the shift will MOOVE you.
84 Silverado, |
09-13-2003, 10:27 AM | #11 |
just open your throttle all the way open (WOT) and hold it there or have someone hold it. the see if the TV cable will go any farther in the same direction. if not loosen it a little till you have just a very mi-nute play in it. then your probably adjusted just right
09-13-2003, 01:49 PM | #12 |
Iamnotanofficerofthelaw
It's better if you have someone in the truck with there foot on the pedal and to the floor.
Then you can go under there and adjust the cable. $1154 for a rebuild w/ Trans-go kit and Vette servo. Feels good.
~Paul~ '96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock '87 S-10 Ext Cab- 2.8L/700r4 KIA Caught fire 12/7/03 |
09-13-2003, 08:29 PM | #13 |
BAD BOW-Silverado XST
A neckbrace is required in my truck.
Gotta love that first shift!! |
