292 Removal with Trans Attached?
I'm working on pulling my engine (292) out and I'd like to leave the 4 speed attached. It doesn't look like the transmission will have clearance between the cross member and the firewall. Will the transmission have to come off the engine to get the engine out?
Re: 292 Removal with Trans Attached?
I left my tranny in the truck and pulled the motor only when I freshed mine up. To pull the tranny I took out the tranny cover and pulled it up and out through the floor with a engine hoist.
http://67-72chevytrucks.com/vboard/s...d.php?t=395922 |
It will come out together with a three speed, not sure about a four speed though. It's much easier if the radiator support and grill are out of the way.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
a bit fiddly but my 292 and sm465 went in as a unit.
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
I managed to get them out together. I had to take the top cover off the transmission. I put a piece of cardboard over the gears to keep from getting anything in the transmission and they slid right out in one piece.
Now the real work begins. I spent 5hrs power washing, brushing and degreasing the chassis this afternoon. Not even close to clean yet. |
It's only four bolts. Two on the outside and two under the plate cover.
