1975 c10 350 to 250 swap
does anyone have pictures of motor mount brackets that bolt to 250 engine for this swap? the 250 is in 76 nova and i dont know if engine side brackets are same for truck. i know frame side ones are same v8 and 6cyl just in different spot. thanks.
Re: 1975 c10 350 to 250 swap
I just went the other way use the brackets on the 250 block. The mounts the bolt slide through are the same but they need to be moved to lower set holes on the truck frame. if you search my threads I have picture about it.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
The best ones I have on hand right now. Hope it helps
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
thanks! they look just like the ones on the 1977 nova the motor is coming out of. the frame mounts are the same ones, anchor pn 2292 says they fit 3000+ vehicles!
