09-29-2015, 12:46 PM | #1 |
1970 Daily Driver
5.3L Turbo Questions
Recently purchased a 5.3L/4l60E setup out of a 2007 2wd Silverado with 60,000 miles on the clock. I am in the process of pulling my 327/nv3500 out of my 70 SWB Chevy to make room for the new power plant. The new to me 5.3l already has a new GM performance oil pan to clear the cross member, new motor mounts, wire harness repin and computer reprogram. I have a Boyd welding gas tank prepped for EFI ready for install. And I am building a new gauge cluster using an 96 s-10 speedo.
I thought I was all ready but then I got my latest issue of Classic Trucks and now want to install a turbo after seeing it done on 67 C10. I tried searching the forum but couldn't find much more than started projects. Anyone know of any build threads that would help. Or have any good advice?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
09-29-2015, 01:47 PM | #2 |
Re: 5.3L Turbo Questions
Yeah, I've got a 5.3 turbo setup in my truck.
Things for a turbo build: 1) Fuel system. You're gonna need a good one capable of pumping a lot of fuel. I run E85, so I went overkill....and it works perfectly. Holley 12-1800 pump, -10an feed, -8an return, 1:1 Holley Fuel Pressure Regulator, 16 gallon Summit fuel cell. Solid fuel delivery make things great. 2) Engine management. The stock ECU "works" but mostly sucks for turbo applications. All WOT fueling is "open loop" so any sort of fuel pressure error (say, I reference line to the regulator popping off) will mean the engine dies. Aftermarket ECU's (Holley, even Microsquirt I believe) have protections. 3) Torque converter/trans. Turbo engines make bonkers torque, so you'll need a good converter for the application as well as a trans that can handle it. I'm running a 4L80E. 4) Exhaust. Run the biggest downpipe (after the turbo) you can make fit. I've got a 3.5" pipe to a 4" section with a dump. Turbos hate backpressure post-turbine. Preturbine, keep it small to spool. It's about heat energy to the turbine more than the traditional thoughts of flow. The rest of the work is basic LS swap type of stuff. For the pipes, I flipped the truck manifolds, cut then welded a 2.5" V-band, reduced to 2", then bought a bunch of 2" piping (J bends, straights, 45s, etc) and started welding. The results are (in my opinion) amazing. The truck idles at 650rpm, drives smooth as a stock vehicle, and pulls like a freight train on the boost. At 10psi I've been a best of 11.44@117.1, 4100lb race weight. Turbos don't need deep rear gears, I'm running a 3.25 in a 9" and have sixty foot times in the 1.63-1.65 range footbraking to 4psi. I ran Hot Rod Drag Week and averaged 11.58@116.5 for the week on low boost. https://www.youtube.com/watch?v=8DCkwtT71E0 Buy good brakes and steering though. On 13psi my truck will spin from a 50+mph kick. I'm hoping to head back to the track soon and use 15psi, going for that 10.99.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
09-29-2015, 06:26 PM | #3 |
^^^ That looks killer! Nice work! I want a turbo
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
09-29-2015, 06:47 PM | #4 |
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
09-29-2015, 07:01 PM | #5 |
Ok here is mine in a 1969 3 door sleeper suburban. I have a 5.3 with a 76mm turbo on basically a stock engine and transmission. The fuel system has been upgraded and I am only running 7 pounds of boost with a 3.07 rear end. All I can say is mama hold on when she is under load! I can't even imagine what it would be like at 10 let alone 15 psi.
This system already exceeds the suspension and braking system I have in the massive suburban. It is a great combination!
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
09-30-2015, 03:27 PM | #6 | |
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
09-30-2015, 09:01 PM | #7 |
Ac is a stock LS compressor in the stock location which fits between the frame rail. Front system is vintage air and the rear is teed into the same hoses for the stock unit in the rear.
09-29-2015, 07:01 PM | #8 |
I'd love to do this to my 2002 Tahoe when it's retired from being my daily driver. Nice turbo setup, lowered a little with some late model Tahoe 20" wheels and a fresh paint job. I already love that old Tahoe so much, can't imagine it like that!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-29-2015, 07:03 PM | #9 |
Here is the suburban in all its glory!
09-29-2015, 08:05 PM | #10 |
meowMEOWmeowMEOW
Whatever your budget, add 30-50% for changes, incidentals, and the first few things that you'll inevitably break when adding that much power.
Find a good tuner. Not a mailorder tune. Not a "3-pulls and your done" tune. A real, logged on the street and tested on the dyno, tune.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-29-2015, 09:10 PM | #11 | |
Here you go |
09-30-2015, 09:44 PM | #12 |
I'll bite. Subscribed to this one!
CT |
10-02-2015, 09:19 AM | #13 |
Subscribed. Great builds. I am putting a 5.3 with turbo in my 66 so this is great info.
10-02-2015, 09:20 AM | #14 |
What is the advantage of welding V bands on the truck manifolds vs using the flange that comes on there?
10-02-2015, 01:46 PM | #15 |
In my case, space and packaging was way easier after cutting the manifolds. Besides, V-bands don't have a gasket or place to fail and they're easy to work with. I don't even run flanges on N/A exhaust these days...
10-02-2015, 11:59 AM | #16 |
Boosted Member
Here is my turbo setup in my sleeper blazer, and the full build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=529064
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-02-2015, 06:28 PM | #17 |
Nevermind.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
10-02-2015, 10:31 PM | #18 |
mine should be done in a couple months... in my sig....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
