09-29-2015, 04:59 PM | #1 |
Need help with brakes
Last night I was driving uptown about to go initiate freshman and I lost my brakes . It was raining out but my brakes were working previously before but not the best. They never reallyw worked the best but now they don't at all .I can pump the brakes and gain some pressure but that doesn't last long at all .So where should I start at to figure out what the problem is. When I first got it running I didn't have brakes .Bleed the front and had brakes. Not the best but enoughf or me. Never did the back .What should I start with?
09-29-2015, 05:05 PM | #2 |
Re: Need help with brakes
is it brake shoes front and rear? or discs up front? either way ensure the brake shoes are correctly adjusted. Adjust the shoes until the drum locks up then back off until it rotates freely.
is it single or twin master cylinder?
my rides 59 GMC Apache fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=684337 68 VW Westy camper |
09-29-2015, 05:53 PM | #3 |
x2. Pull the wheel off first though. I always used have the brakes tight enough to where I can spin the drum just one full rotation and you should be good. If you keep tightening and it spins 2+ rotations you will want to replace the shoes.. just my own personal rule of thumb...
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
09-29-2015, 05:47 PM | #4 |
Single cylinder .Original brakes. I know absolutely nothing about brakes so I don't know what a shoe is
09-29-2015, 05:55 PM | #5 |
Brake shoes are the predecessor to pads and push out on the interior of the drum to stop, just as brake pad pinch the disc in disc brakes to stop.
09-29-2015, 06:23 PM | #6 |
Alright I'll do that when I get a chance. I went out and messed with it .I barely had any brake fluid in it. So I put some in and pumped the brakes and I have pressurea again. But if I keep my foot on the brake it slowly loses pressure until it's to the floor. Or else I have brake pressure and then I push again and there's none
09-29-2015, 06:32 PM | #7 | |
09-29-2015, 07:51 PM | #8 |
If your system is the original single pot master cylinder I would look into splitting the system and updating it. Brakes are the most important safety item on the truck. When you say " Not the best but enoughf or me." that scares me some when you don't know what a brake shoe is. Please find some qualified help to get this truck a good set of brakes. Some will say the single pot is good enough but they have never wrecked one when it wasn't. I had a line split on my 64 many years ago and hit a van in the back. I think you will find a bad wheel cylinder on the truck and that where the fluid went and why you never had back brakes. Spend the time and money to rebuild it all and split the system.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-29-2015, 08:55 PM | #9 | |
09-29-2015, 09:17 PM | #10 |
What are you gonna put that motor in after you tear your truck up because you have no brakes? Brakes are priority if you gonna drive it. You have to think of other people on the road, not just yourself.
09-29-2015, 10:40 PM | #11 |
No brakes will be coming soon .I'll definitely have the brakes done by the time I have the motor done without a doubt. I won't be driving it at all without brakes . Before it wasn't bad. But past few weeks it's been getting worse . That's why I haven't been driving it in awhile . Yesterday was first time I've drove her in weeks .
09-30-2015, 06:59 AM | #12 |
Looks like you are in an automotive program if you are doing an engine for your senior project. Ask for help from someone who knows brakes. Splitting the system is not to hard and several threads in the FAQ section above on brakes and upgrades for them. First step is to get it up on stands and pull the wheels. take a look at the condition of all the hoses and lines. Look for rusted metal brakes lines and dry rotted hoses. Pull the drums and look at the condition of everything in there. The shoes and wheel cylinders. On a wheel cylinder pull the rubber boot back and look for brake fluid and corrosion. This will let you make a plan for what you need to make it safe. Step two. PM me your address. I have a complete set of wheel cylinders, hoses and brake shoes for the front that were on one of my trucks less than 6 months before I went to disc brakes. I'll send you a care package. For how all this stuff works youtube is a good resource.
Jimmy
09-30-2015, 11:42 AM | #13 |
Thanks I pmed you. No I am not in a automotive program. Engine displacment and racingi s a family thing. And in a small town like this there's nothing more to do than drive around andthe town trend is classic trucks .Most of the "cool kids" have classic trucks .That is what I plan to do this weekend is get it on Jack stands and see how it all looks.
09-30-2015, 12:12 PM | #14 |
don't worry about up-grading now. Pull all the wheels and drums and check for leaks from the wheel cylinders and all line connections. No leaks bleed all the wheels cyl. still no brakes probably need a new master cylinder. if you need to know something ask here or goggle is at you finger tips--- maybe ask one of the tk guy's in town to give you a hand.----------good luck
1961 chevy K10 my build is------------61K10 build |
09-30-2015, 01:51 PM | #15 |
Brakes are a cheap fix considering what they do for you. Losing pedal pressure could mean a few things, and might be solved with a cheap $25 master cylinder, but if you are actually losing fluid somewhere, catastrophic failure is imminent. NO JOKE - when your brakes fail, you hit whatever is in front of you at whatever speed you are going. You or someone else might die the next time out.
A split hose, a leaking wheel cylinder, a loose fitting, or whatever... all are simple and inexpensive repairs. Stop driving the truck until you can trace the fluid loss. It should be easy enough to spot, as it will be wet with fluid around the source. |
09-30-2015, 03:03 PM | #16 |
First. Look at the back of each wheel to see if they are wet with brake fluid. If they are dry, try looking under the dash where the brake rod goes into the master cylinder. If you see fluid inside then your master is bad. Time to get a two pot master and split it up.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-30-2015, 04:19 PM | #17 |
I agree with all that's been said ,remember it does you no good to have a truck that can go if it cant stop ! The life you save may be mine .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
09-30-2015, 04:51 PM | #18 |
Thanks for all the help .Like I said I haven't been driving it .It doesn't go out of town either it's just my drive around truck. I knew the brakes were needing work so I parked it.
10-01-2015, 07:01 AM | #19 |
So far I have front brake shoes and hardware, wheel cylinders an hoses for the front. Still digging through stuff.
Jimmy
10-01-2015, 06:36 PM | #20 |
Thank you very very much .If all goes well I'll pull it up to the garage this weekend and start looking into everything and see how it looks
